Old 12-12-2009, 09:41 AM
Onthehard Onthehard is offline
Paint below the waterline
If they use swimming pool paint to keep water in a pool, why can't you use the same paint below the water line to keep water out of your hull?
Why can't you use something ruberized like Sno Roof or Rhino Liner?
Old 12-12-2009, 09:46 AM
mark775
If your pool leaks, the water runs into the sand. The worst that can happen is that the pool floats a bit and cracks. The converse is that if your goo leaks, the boat doesn't float.
How do you find the waterline? help evilpriest Stability 2 07-15-2008 07:35 PM
How To Scribe A Waterline abckits Wooden Boat Building and Restoration 5 05-28-2008 07:33 AM
Find the waterline bentshaft Boat Design 1 03-16-2008 02:25 PM
Confusion Below the Waterline Texas Boater Wooden Boat Building and Restoration 2 05-20-2006 03:40 PM
designed waterline? huw Boat Design 3 06-05-2004 12:29 AM
