Old 08-10-2009, 09:42 AM
waterbaby waterbaby is offline
Rep: 10 Posts: 4
Paint
I have to admit I fell for the slick adcopy on the homepage of Top Secret/Supermarine paint. I bought over $500 worth of their paint, primer and thinners.
After wasting months trying to getting decent results on my boat with various techniques (rolling, brushing, roll and tip and spray) I finally gave up and purchased Interlux Brightsides and it looks marvelous.
The TS paint would not “flow”to give a smooth finish. When I wet sanded it with 320 grit wet or dry sandpaper the paint was so rough that in places I wore through the paint and could see the original gelcoat or primer. I would paint the bad spots again, only to get the same result over and over. I thought it was my technique. Their floor grip paint was just as bad, separating immediately and giving an excessively rough, uneven finish. When I repeatedly called and emailed TS for advice they “fixed”their problem by refusing to answer.
I finally ”bit the bullet” and decided to purchase another brand. After reading all the reviews I could find, I emailed the major marine paint manufacturers with questions , and received a personal, detailed response to my questions from Interlux, better than anyone else's response, so I decided to go with them. So far I have not regretted my decision at all!
Brightsides is great at leveling after it is applied. There is no need to sand out bad places, there aren't any! The finish is incredible, it looks like it's still wet. My endless days of sanding are over, the project is moving forward again. Now if it just holds up well it will be the “perfect” 1-part paint!
To paint or not to paint over 3m 5200 BurnabyRocket61 Materials 3 09-01-2008 09:45 PM
Paint Help! DeputyMike Fiberglass and Composite Boat Building 26 09-05-2007 09:56 PM
My paint has come off ! Dave-Fethiye Wooden Boat Building and Restoration 12 08-16-2007 07:15 AM
Need Paint Help flydog Boat Design 4 04-15-2007 04:39 PM
Paint? anotherhassel Powerboats 3 12-22-2006 06:00 AM
