| P-welting i'm looking for vinyl extrusion to be placed between the edge of an interior bulkhead (actually a partition) and the interior of the cabin top -- the function anticipated is that of appearance, and to prevent squeeks... the boat under remodel is an '84 J-24. the origninal manufacturers material is no longer available, and in fact the current manufacturer has no supplier of this material (which i find hard to believe...). the configuration of the extrusion can generally be described as the letter "P". a "tadpole" shape (round with a tail on-center) would work as well. the length overall is about 1-1/8" and the diameter of the bulb is 7/16" -- the leg portion needs to be about 3/4". any leads would be appreciated Lew |
