  #31
Old 08-21-2011, 03:38 AM
Boat Design Net Moderator Boat Design Net Moderator is online now
Moderator
Rep: 647 Posts: 184
Sometimes disagreements start off on the wrong foot, but if we could get to specific details -- what exact resin, solvent percentage, marine ply or other wood, and how were properties tested -- a more useful discussion could develop.
Please be polite to all other members. Please respect those who take their time to give advice freely. And please keep threads on topic. Forum Rules
  #32
Old 08-21-2011, 09:29 AM
Steve W Steve W is offline
Rep: 360 Posts: 686
Originally Posted by Lister View Post
Sorry ladies, I have to defend Paul. His epoxy is the best you can buy.
He knows what is talking about.
Lister
Could you please explain how you arrived at this conclusion.
Steve.
  #33
Old 08-21-2011, 01:02 PM
Lister Lister is offline
Moxy
Rep: 45 Posts: 172
Steve.
Contrary to you BY USING IT genius
Lister
"I always like walking in the rain," he said, "so no one can see me crying."
Charlie Chaplin
  #34
Old 08-21-2011, 01:10 PM
Moxy
Rep: 45 Posts: 172
Someone wrote with his negative:
You start the attacks on people then beg for mommy to come save you
Interesting tone. Show the quality of this particular thread.
The moderator is not my mommy, is the moderator. Perhaps if you don't know what a moderator is, I suggest you get out of the forum.
One thing everyone has to understand, I tell the truth, and all the anonymous negative will not change my course of action.
I AM THE ONLY ONE HERE WHO USE PAUL PRODUCT.
So all of you please refrain to be stupid and ignorant with your so-call proficiency in chemistry (which by the you don't have)
So to all my red dot friend, get real, and start working inset of gossiping. Use your finger to write a check to Paul for buying its product, and then come back.
If you are no too stingy.
Lister
Charlie Chaplin
  #35
Old 08-21-2011, 02:25 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,055
Perhaps.. but it never was about Pauls products and I'm sure they are top quality.. The question was about using solvent with epoxy, so tell us if you do that..
BR Teddy
  #36
Old 08-21-2011, 05:10 PM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,842
No...you aren't. I have used probably 10 times as much as you have. I have used it unadulterated and as such it works quite well. The question for me then becomes why should this....of all the epoxies on the market that specifically recommend not thinning...be thinable by the consumer. I too would like to see actual numbers and not anecdotal information.
As to your tone...perhaps you are the one should consider leaving the forum. If you can't carry on a discussion like a civilized, educated adult then most people here won't be interested in anything you have to say anyways.
  #37
Old 08-21-2011, 05:30 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,400
Thanks LB - couldn't have said it better.
And, to add, its not the person who has used a single particular product who is the authority on it - its the person who has used MANY different products, and has rigorously compared and tested them all, who has the most credence.
But I digress - this is about the science of 'thinning' - and as LB says - lets see actual figures and discussion on it being a good idea, as opposed to all the figures that say its often not a good idea.
The reports I have read ( and included earlier ) indicate that with most epoxies
1) It doesn't improve adhesion
2) It creates a water permeable layer
3) It creates a mechanically inferior bond.
  #38
Old 08-21-2011, 05:39 PM
Rep: 360 Posts: 686
Lister, you made a blanket statement that Pauls epoxy is "the best that you can buy" then you stated in another post that you have used just 8 gallons of it? now im not disputing that it is good epoxy, im sure it is but the best that you can buy? that needs to be explained. What other epoxies have you tested it against, how did you conduct your tests? How much epoxy have you used in your lifetime? ive used thousands of gallons over more than 35yrs from many different manufacturers and i couldnt say that any one brand is "the best you can buy" some work better than others for different purposes.
BTW,thank you for the compliment.
Steve.
  #39
Old 08-21-2011, 07:42 PM
Moxy
Rep: 45 Posts: 172
Steve.
OK you are a genuine genius realy, you used far more epoxy than me on my all life and you surely know more about it than me! And I mean it.
My test are not conducted scientifically, just by using it.
The 8 gallons I mentioned was the gallons I bought from him. not the total of gallons from the West, Three and other Systems.
I used the Ciba brand in the 1960 from Switzerland, then using it latter on building the tortured plywood Tornado, and also building with the same system International Moth.
That was the recreational part of my job, normally using tons of coal tar epoxy on the barges.
Also using epoxy for cheap and fast repair. It came on unmarked pails but the best one always came with a 1 to 1 mixture or one to 2 mixture. I find the one to 5 or 4, not flexible enough, and not temperature forgiven.
I slaped the darn thing, I don't studied it. I just follow if it fail or not.
The Paul one never failed, the West had is own share of problems.
Perhaps its me.
I just use it, I don't study it. Doesn't worth it.
Lister
Charlie Chaplin
  #40
Old 08-22-2011, 08:09 AM
Rep: 360 Posts: 686
Lister, Actually using and observing over a long period of time in the real world is plenty good enough. Most of us need a good all around epoxy and most (but not all) i have used are more than adequate and it comes down to ease of use more than anything and, like you i dont like brittle epoxies,there has never been a time in my career when ive said to myself, gee,i wish i had a more brittle epoxy. I too used a fair bit of Ciba Giegy Araldite and lots of Epiglass back in the 70s and thousand of gallons of Ciba,Jeffco and Hardman press molding epoxies in my snowboard manufacturing days in the 90s in the US and Taiwan and we did a lot of lab testing in those days as they are a lot more demanding to build and have stay together than boats. These days i like to try the different epoxies on the market and will be sure to try Pauls at some point.
Steve.
Osmosis on my Sadler 29 dickonclark Fiberglass and Composite Boat Building 4 05-16-2011 02:39 PM
Osmosis Treatment Willallison Boatbuilding 8 01-21-2011 03:27 PM
epoxy,epoxy, opps flooring epoxy aboyd Materials 5 09-12-2009 02:56 PM
Osmosis - Fresh Water vs Salt Water andy_uk Fiberglass and Composite Boat Building 0 05-21-2008 02:40 AM
epoxy primer sprayed on green epoxy laminate? bntii Boatbuilding 12 10-16-2006 06:41 AM
