Old 07-07-2002, 09:18 PM
JohnK JohnK is offline
Rep: 10 Posts: 5
One Piece Shower nit.
Where does one obtain the one piece shower units used in todays Boats?
Old 07-08-2002, 06:53 AM
Nomad Nomad is offline
Mold Trader/Boat Builder
Rep: 12 Posts: 462
Could you better explain? Might just be me though.
Old 07-08-2002, 09:04 AM
james_r james_r is offline
Rep: 10 Posts: 44
I'm assuming that you're talking about the head/shower compartment. Manufacturers will typically make it themselves out of fibreglass from a male mould of their own design.
Old 07-08-2002, 07:41 PM
Rep: 12 Posts: 462
That's what I was thinking, wanted to check.
Old 07-09-2002, 06:29 AM
Rep: 10 Posts: 5
Sorry for the delay. Yes I am looking for the one piece shower/head units used by boat manufacturers. I wanted to know if these were like the ones you use in your home. Most of them look to be manufactured out of plastic. Thanks.
Old 07-09-2002, 10:22 AM
Rep: 10 Posts: 44
Yes, they're pretty much made the same way as home shower units. The whole thing is made in one piece over an upside down male mould. Since it's not a structural item, it's usually laid up using a chopper gun or CSM. The only reinforcement is usually plywood or some other core material in the floor area. After popping off the mould any openings (door, drains, etc.) are cut and the unit is bonded to the hull and bulkheads.
Old 07-09-2002, 04:25 PM
Rep: 12 Posts: 462
Mine are a little different the are fiberglass but do not need wood for stiffness the are built strong enough and shaped to where it is bonded to various parts of the vessel. (hull, sides, stringers, bulkheads, etc.)
Always kick the soap to the side of the shower... Sean Herron Open Discussion: All Things Boats & Boating 9 09-25-2005 06:58 PM
2 piece Vs. 3 piece Hulls image691 Boat Design 12 08-07-2005 08:55 AM
One piece hull structure molding Okie Boat Design 6 05-09-2005 08:34 AM
Bent Trim Piece mikkyle Fiberglass and Composite Boat Building 3 12-26-2004 09:15 PM
teak and holly plywood piece modunlavy Boatbuilding 1 03-30-2004 09:09 AM
