Old 09-16-2006, 10:41 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
Thanks Jack but Im on a lttle island east of Malaysia. I have difficlty buying bread some days.
I have bought a liter tin of silica sand ( fine ) and I was,-- when I get my act together is iether sprikle or mix into the Jotun AS Eurothane 2 pack white which I will buy in Thailand on my next visit.
I have previously posted here that i thought of making a sprinker from a card board box with holes in it. For some strange reason my thinking is that this would cause the least cock up.
Old 09-16-2006, 10:45 PM
Rep: 95 Posts: 462
that will work too,
Old 09-20-2006, 06:56 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1117 Posts: 1,648
Try here for TBS http://www.proboat.co.uk/category.asp?dep=2&cat_id=39
Pericles
Old 09-20-2006, 11:52 PM
Richard Hillsid Richard Hillsid is offline
Rep: 19 Posts: 117
Originally Posted by jack frost
I need to do quite a lot of non stick in the next few months after rainy season. I want do the whole swim platform of my catamaran.
I just sprinkle it on or through it on, (don’t actually poor it on)
Its not really lumpy at all if yu get it on evenly, if you are using a primer get that on first, then paint your for example polyurethane paint, then sprinkle this on, after its dry brush of the extra.
Sandblasting sand gives a very good grip but is sharp on the knees if you faal, the more over coats you use the less sharp it gets.
My dad said he used crushed peanut shells in the 60’s in CA it was a lot softer.
If you want stripes, tape the non striped areas, paint the job and apply sand or beads, (attention micro-balloons haven’t worked for me at all, but test them too),
You need to make a small test batch, use any old warmish or PU paint you have left over, try different areas with different overcoats etc.
You get a pro look if you test it a few times first on some old peace of counter top or other sheet with a laminate on it.
Remember that all the normal pre painting fairing sanding etc must be done as all niks show right through.
The test panel you make is cheap or costs nothing but your time.
Richard.
Old 09-21-2006, 02:22 AM
yotphix yotphix is offline
Rep: 16 Posts: 45
I tried putting it in the paint and rolling it on once with terribly ugly results. I found that it left streaky lines of sand. Your results will definitely be more consitant if you scatter on wet. I did it by hand with good results but had thought to try a pringles tube with a line of holes up one side next time.
Old 09-21-2006, 02:25 AM
Rep: 16 Posts: 45
Incidentally thenicest results are sprayed on with the paint using a pressure pot rig being gently shaken by te painter's helper all the while. That's how the pro's do it at the yards in south florida I've been in.
Hinged Decking Poida Powerboats 2 05-08-2006 05:05 AM
Why so much slip? navy boi Propulsion 11 04-19-2005 11:00 AM
Why so much slip? navy boi Open Discussion: All Things Boats & Boating 0 03-16-2005 01:21 AM
Decking Materials {NW}BKUSA Materials 15 11-22-2004 12:07 PM
Composite decking Busted Knuckle Wooden Boat Building and Restoration 4 06-02-2004 02:58 PM
