Old 06-14-2010, 06:50 PM
Mat-C Mat-C is offline
Rep: 109 Posts: 242
Non-developable shapes in aluminium
Many texts state that one of the good attributes of aluminium is that you aren't restricted to using developable shapes.
But just how practical is it to form say the hull bottom with compound curvature?
Is there a lot more work involved?
Old 06-14-2010, 11:45 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
...if you intend to do compound curving in metal, try the constant camber method, it is very easy to roll the spapes and then to weld em in....simple work and the result looks impressive.
Old 06-15-2010, 12:32 AM
Rep: 109 Posts: 242
Thanks Landlubber.
I'm vaguelu familiar with CC in plywood boats - a variation on cold-molding, if I understand correctly - but how is it done with metal?
Old 06-15-2010, 12:51 AM
Landlubber's Avatar
same principles of construction, only it is stuck together differently.....
Old 06-15-2010, 01:20 AM
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
Forming compound curves in heavy aluminum plate
take a look at the whole thread
plate wheel machine and technique
and here
I sent you a pm too
developable panels DriesLaas Boat Design 16 10-23-2009 02:24 PM
Developable surfaces Boysie Boat Design 11 04-12-2008 04:22 PM
Help need to build a developable deck NorthCaptain Boat Design 0 06-16-2007 01:41 PM
Matlab and developable surfaces mizzenman Software 1 03-19-2007 03:27 PM
non - developable surface in aluminum lbh110 Materials 2 02-16-2007 02:45 PM
