Old 09-28-2009, 08:49 PM
boat fan's Avatar
boat fan boat fan is offline
Rep: 357 Posts: 679
Nidacore...is it cost effective for interior fit out ?
Hello .
I was wondering if anyone had any experience with Nidacore ?
Is it competitive in cost to plywood / epoxy glass laminate for interior
fit out , cabinets , doors , (maybe not bulkheads).
Also , what is the best way to get a tough paint like finish ( plain white ) with Nidacore ?
Old 10-01-2009, 02:45 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 987 Posts: 1,178
Nidacore is just what it is: Core. It needs skins. Skin finish is dependant on the skin used, of course.
My experience with Nida is that the shear modulus (stiffness) is somewhat low, and density is somewhat high. Price is OK, though.
Still for any next project I would use low density foam (60 kg/m3)
Old 10-09-2009, 04:16 PM
mikereed100 mikereed100 is offline
Rep: 30 Posts: 82
In Australia I believe you will find that Polycore is quite a bit cheaper than Nidacore.
http://www.polycore-australia.com.au...nd--Events.php
Here in the Great Satan we pay something like $120/sheet for 25mm Nidacore and $50 for the same by Polycore.
Mike
Old 10-09-2009, 06:21 PM
boat fan's Avatar
Rep: 357 Posts: 679
Mike
Wow !!!!
Old 10-09-2009, 07:17 PM
sabahcat's Avatar
sabahcat sabahcat is offline
Rep: 224 Posts: 716
Mike
They do pre glassed sheets as well.
When you compare the prices to what the greatest of satans (ATL) sell duflex or other product for, you are well in front.
Not sure if you are in front compared to 6mm okhume ply with cedar /kiri supports, but I am interested enough that I am doing the numbers now.
Old 10-09-2009, 07:51 PM
boat fan's Avatar
Rep: 357 Posts: 679
Yes I would be really interested in that too.
Particularly with the glassed finish panels compared to plywood / epoxy coated .
I have always suspected " evil doings " with the price markup of ......
DUFLEX ...OUTRAGEOUS !!!!
Old 10-09-2009, 08:00 PM
apex1
A 1-3mm veneer on Kiri core will outperform the plastic crap in almost every sensible application, and add substantially to the whole structures strength. For just a very, very small weight penalty.
Old 10-09-2009, 08:40 PM
Alik's Avatar
Alik Alik is offline
Rep: 1020 Posts: 1,893
2apex1: consider HexaCor also, similar prodct, reasonable price... Can be glued with plywood or other surface finish with vaccum.
I can never undersrand why 1m2 of Dyvinicell foam or Duflex cost like a computer
Old 10-09-2009, 10:44 PM
boat fan's Avatar
Rep: 357 Posts: 679
Now THAT does sound sensible !!!!
Can you buy it , or need to do yourself apex ?
What about glass laminate instead of veneer ? ( I like plain old white (2 pack maybe?) paint finish )
I can never understand why 1m2 of Dyvinicell foam or Duflex cost like a computer
No , neither can I ....Sabbah has it right I think ...EVIL
Old 10-10-2009, 05:45 AM
apex1
Need to veneer it yourself. But of course you do´nt need to veneer a good wood like Kiri. When the application is just cabinetry leave it as it is. It has a warm, bright Honey like tone when varnished. Or paint it when you like. Of course you can apply a layer of glass, but apart from abrasion resistance for what would you need that? The advantage of using such a light wood instead of foam core: you do´nt need all the hell of a lot of work to reinforce the million edges, hinges, holes etc.
Alik
I completely agree on Hexacore!
Richard
Old 10-10-2009, 06:38 AM
sabahcat's Avatar
Rep: 224 Posts: 716
Definitely more expensive than raw material (6mm Oakume/gaboon resin soaked ply) but the ease of just picking up a pre glassed sheet?
Could possibly be worth it in some areas, maybe.
Nah, I think I just talked myself out of it again. Stick with ply me thinks, plus I have 20 sheets already waiting to go in.
Old 10-10-2009, 07:53 PM
boat fan's Avatar
Rep: 357 Posts: 679
Need to veneer it yourself. But of course you do´nt need to veneer a good wood like Kiri. When the application is just cabinetry leave it as it is. It has a warm, bright Honey like tone when varnished. Or paint it when you like. Of course you can apply a layer of glass, but apart from abrasion resistance for what would you need that? The advantage of using such a light wood instead of foam core: you do´nt need all the hell of a lot of work to reinforce the million edges, hinges, holes etc....
Richard
Richard , I really don`t like the appearance of any kind of " wood " finish on any interior surfaces .Some light colored solid trim is ok.
I`m really tired of looking at " wood " inside a boat. Especially the darker woods and ESPECIALLY TEAK...that look has had it`s day and then some !
Dark wooden interiors often make a boat look like a cave to my eye. Does anyone feel the same ?
I was thinking of a hard durable surface when I mentioned glass laminate Richard. Kiri is quite soft . It can gouge and scratch easily. But I do like the stuff ...it`s so light. It`s easy on cutting tools as well.
I guess you could just epoxy coat it with resin , then paint.
I know that there are many people that would not agree with the wood thing ... , but its just my taste.
Old 10-10-2009, 08:05 PM
apex1
=boat fan;306007
Right, that is the way you could do it! The wood is indeed a very soft one and will dent even when you lay some epoxy on it. Give it a cover of fine cloth 60gsm or so, that will do the trick and it looks outstanding good when you do NOT fill the weaves ? (right word?) with too much resin, so there is just a touch of cloth like surface when you have painted it. And what should be wrong with plain white paint? When there are some wooden applications that looks quite good! And in warmer climates a white room "feels" cooler than a plushy dark mahogany salon.
But back to the foam core as alternative. When you imagine you must lay a small strip of wood in all four edges of a door, or cabinet wall and the like. You must reinforce every hinge (wood again), and so on.
No, better sheath Kiri with glass (much more than 60gsm when it has to become structural) and forget about the foam sh!t.
You are in the right corner of the world for Kiri (though it is rather expensive there), so take the advantages! Compared with core foam of the worst quality it still costs nearly nothing. And there are no doubts about bonding, shear strength, delamination, water ingress and so on.....
Regards
Richard
Old 10-10-2009, 08:34 PM
sabahcat's Avatar
Rep: 224 Posts: 716
http://www.made-in-china.com/product...ode=0&step=999
http://www.kiripark.com.au/Highpoint/highpoint.htm
http://www.portphillip.com.au/timberpanels.html
Old 10-10-2009, 08:37 PM
boat fan's Avatar
Rep: 357 Posts: 679
Yes ...too much work and too much money.
so on.
Yes ......we do have a lot of plantation grown Kiri here. Western Australia especially.It does make a lot of sense Richard.
nidacore - in jamestown rapscallion Materials 0 08-11-2008 10:12 PM
NidaCore Pourable Transom Compound dberr Fiberglass and Composite Boat Building 0 06-20-2007 06:24 PM
Info on Nidacore Spud Fiberglass and Composite Boat Building 18 05-18-2006 07:33 PM
Who can make me a cost effective mold for a 11ft polyethylene hull? sir-speed Boatbuilding 4 06-02-2005 10:26 AM
Yacht Interior Fit-out Manager (X2) Daniel Fenton Services & Employment 0 10-31-2004 07:47 PM
