Old 03-06-2004, 02:13 AM
jimcorliss jimcorliss is offline
Rep: 10 Posts: 5
Newbie wants feedback about a foam roof...
Hi, I'm new and glad to find your forum !
I'm building a 22' SISU lobster boat up from a hull and was considering a foam roof.
Figure It will be stiffer and require less stiffening than if I just glassed over 1/2" ply.
I'd also like the roof to support a persons weight.
Any suggestions as to thickness and density of foam and number of coats of structural or vector ply glass on each side. I think roof size will be ~ 7x8'
also might consider doing the cabin with foam as well.
money is VERY tight.... so cost is major factor and I might just finish in 1/2"cdx .
There are great builders here who can advise me but I do appreciate any feedback from you as well.
Thanks ! Jim
Old 03-10-2004, 06:23 PM
cgorton cgorton is offline
Rep: 10 Posts: 50
Did you get my email? Check out the fiberglass construction forum- we're having the same discussion there.
Craig
Airex and any foam based hull materials tdamico Boat Design 21 03-04-2009 08:26 PM
Pourable foam, need advice BustedKnuckle Materials 6 07-10-2006 09:19 PM
Foam Block To Bass Boat... can this be done? Curious Fiberglass and Composite Boat Building 10 12-11-2004 07:21 PM
Foam substitution---PAR? johnsonmtz Materials 2 04-24-2004 10:48 AM
Foam / Plywood Boat Plug Construction ?s cla17 Materials 2 05-18-2003 07:45 PM
