Old 08-21-2007, 10:37 PM
Jbird Jbird is offline
Rep: 10 Posts: 5
Newbie with glass ID question
Thanks for letting me into your forum. I got a 1971 Larson trihull with a four cylinder Chevy IO powertrain and four holes in the hull. Two of the holes were caused by an over zealous skill sawer and two were caused by me, a loose chain and a forklift. I need to find out what kind of fiberglass to use to repair the oopses. I have both epoxy and polyester resins and several types of mat and cloth. Where can I find out what the hull was originally made with and should I use that material to repair the hull below the water line.
I've built a couple of glass car bodies but you don't have to worry about them sinking. Thanks for any help. Jbird
Old 08-21-2007, 10:55 PM
timgoz's Avatar
timgoz timgoz is offline
Rep: 262 Posts: 1,067
Hi JBird,
In 1971 they were almost certainly using poly resin. That and glass cloth will probably make for a functional repair.
Nice to have you as a member.
Take care.
Tim
Newbie here with newbie question. Marine plywood or plywood? photojunky Wooden Boat Building and Restoration 30 07-23-2007 06:41 AM
A newbie question about fiberglassing my boat namrufmot Fiberglass and Composite Boat Building 6 06-07-2007 10:37 PM
Newbie here has a question about a Dingy Chuck R Wooden Boat Building and Restoration 6 05-07-2007 10:32 PM
Newbie Question Scottlaf Fiberglass and Composite Boat Building 2 11-10-2006 06:37 PM
newbie with a question wolter9 Fiberglass and Composite Boat Building 6 07-01-2006 06:41 PM
