Old 09-08-2008, 08:50 PM
Fisherball Fisherball is offline
New Treated Lumber?
I'm thinking about building a small plywood canoe as my 2nd boat building project. First was 41 years ago, I forget some stuff. Anyway living in central Ohio marine grade woods are hard to come by. I checked Lowes, they have luan that I think will work. It's all got the new treatment that is basically a poison. Does it work with fiber glass resins & epoxies? Can you still buy wood that doesn't have that treatment.
Old 09-09-2008, 12:07 AM
PAR PAR is online now
Rep: 3125 Posts: 9,403
The old PT stuff (CCA) and the new stuff (CA) doesn't take epoxy very well and polyester shouldn't be considered, as it just doesn't stick to wood well at all.
Yes, you can still find the "good stuff", though you'll likely have to have a local lumber house order it or you can use mail order. The lauan found in the big box stores is generally junk, unless you're looking for a disposable boat, then I'd avoid it.
Which Lumber? holly Multihulls 4 09-07-2007 01:17 PM
Pressure Treated Plywood??????? mcattac Materials 4 07-10-2007 03:07 PM
Pressure treated yoods ted655 Materials 6 12-21-2005 08:58 AM
Epoxy and pressure treated wood ted655 Materials 2 07-20-2005 05:52 PM
plastic lumber fritzdfk Materials 2 03-20-2005 07:54 AM
