Old 07-22-2011, 09:33 AM
CatBuilder CatBuilder is offline
Rep: 1308 Posts: 3,040
Need Stainless Steel Tubing Source For Rudder Tubes
Does anyone know where I can find very high quality 316 stainless tubing for use as my rudder tubes?
Ideally, I'm looking for something in North Florida, Jersey, PA, Carolinas or Georgia for local pickup, but will order online as a last resort.
Kurt Hughes was right about this place.
Old 07-22-2011, 11:12 AM
Life moves faster than the internet sometimes.
I have found some available tubing, but it's from China. Can I trust it? Is there any quality stainless made in the USA, or imported here from Germany or something, or is Chinese stainless the only game in town?
At $1000 for the tubing and $1500 for other materials for rudders, it seems I'd want to get the highest quality material possible.
Any ideas on this? Anyone know the US steel market?
Old 07-22-2011, 02:44 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,055
If there's any welds you better to have 316L..
Try here :
1101 North Main Street
Wildwood, FL 34785-3432,
(352) 748-1313
They should have Outokumpu stainless steel from Finland..
Old 07-22-2011, 04:16 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1874 Posts: 3,357
http://www.stainless-structurals.com/
Stainless Structurals, LLC · 590 Beautyrest Avenue · Jacksonville, Florida 32254
Phone: 904-781-6447 · Fax: 904-781-6444 · Toll Free: 877-739-6057
"Distributor of stainless steel shapes including beams, channels, angles, square & rectangular tubes, tread plate, smooth plate, cold drawn flats, half rounds & bar products. Special shapes including tees & zees are also available. Steel shapes are manufactured by rolling, or LaserCon® fusion methods. Annealed & pickled shapes are also available. Steel grades include 304, 304 L, 316 & 316 L. Products meet QQS, ASTM, ASME & AMS specifications."
"If you don’t see the shape you need give us a call. There’s a good probability that we can manufacture it, even in small quantities."
Phone: 904-781-6447
Hoyt
Old 07-22-2011, 04:23 PM
hoytedow's Avatar
Resistor
We would very much like to see a couple of photos of your progress.
Hoyt
Old 07-22-2011, 05:22 PM
No welds, guys. It's mostly a composite rudder with a proprietary system to keep it all together. I'm not sure I should give up Kurt's secret here, so I'll just have to say the tube isn't welded at all.
Old 07-22-2011, 06:55 PM
hoytedow's Avatar
Resistor
So you need it extruded as a tube, right?
Hoyt
Old 07-22-2011, 07:01 PM
hoytedow's Avatar
Resistor
http://www.plymouth.com/seacure.aspx
Hoyt
Old 07-22-2011, 08:49 PM
whitepointer23 whitepointer23 is offline
Rep: 247 Posts: 655
do you need steel cat, the last time i had to make a rudder tube and stern tube , i purchased fibreglass tube and glassed it in.
brendan .
Old 07-22-2011, 08:56 PM
waikikin's Avatar
waikikin waikikin is offline
Rep: 596 Posts: 1,026
Catbuilder, we used to use a stainless boiler tube from Sandvik, about 60mm with @ 6mm wall. dunno if they have Sandvik in US though.......... http://www.sandvik.com/sandvik/0140/...e!OpenDocument ...........this might link . Regards from Jeff PS: we also would install a sleeve inside the tube inway of the lower bearing.
Old 07-23-2011, 04:51 AM
Oh boy, I hope I'm not using the wrong terminology here. The last couple posts make me think I made a mistake. Sorry if I did.
By stainless steel tubing for the rudders, I mean the tubing used for the rudder posts, which are hollow. My mistake. I don't mean that I need any kind of tube inside the boat to house the rudder post, but just the post itself, which is (confusingly) made from a stainless steel tube.
My rudders are the kick up style, so they aren't even technically inside the boat. There is no "tube" per se inside the boat, but rather just a couple of bushings outside the boat on the cassette that swings and allows the rudder to kick up.
Sorry for any confusion.
Old 07-23-2011, 06:59 PM
waikikin's Avatar
Rudder "stock"
Stainless steel developements! nukisen Marketplace 0 06-02-2011 03:11 AM
A question about rudder tubes Jacuzzitub Sailboats 3 04-17-2011 03:40 PM
Can I build my own stainless rudder? mongo75 Inboards 7 08-21-2008 03:08 PM
wanted: a source for 1.25" stainless rail fittings pabble Materials 0 07-19-2007 04:53 PM
Source for Steel/Aluminum Handholds JPC Materials 0 11-29-2005 02:26 AM
