| Need plastic/foam advice for rescue boat The project is a car-toppable rescue boat that can be unloaded & launched by one person . . . hopefully under 85 pounds. Since it must be stable and carry a large load, we started with 4.0 ft wide and 12 ft long. It also needs to be foam-filled for coast guard approval and/or unsinkability. Preliminary designs indicated that weight was getting out of hand, so we're reducing length to 10 ft. and width to 40 inches. The boat will be mishandled, dropped, pulled over logs, and otherwise abused. We assume it will be rotomolded, but are open to any construction method. We need advice on materials, molding, foam-filling, manufaturing partners, etc. Meeting tomorrow with design team and swift-water rescue instructors. John Zimmerlee Marietta GA |
| I'd look at boats like a Thundercat (or smaller versions of similar inflatable catamarans) as a reference - ie, something to beat in terms of weight, stability, capacity, ride, etc. Does anyone have a breakdown of the weights in something like a Thundercat? I suppose you can use rotomoulded hulls and still use air inflation to make them stiffer. |
| Do you mean completely filled with foam or only enough for USCG floatation regulations?
__________________ Gonzo |
| any of our tinnies here will do the trick..try Stacer, Quintrex etc...the seats are filled with foam and they float to the gun'les
| I'd also consider the ability to take a wave over the bow and keep on going (without retaining 500kg of water). May or may not apply to your circumstances. ![]() |
| advice on mending broken plastic seat on kayak | kanaya | Fiberglass and Composite Boat Building | 4 | 06-05-2009 10:00 PM |
| rescue boat desing project needed help | AUNG SAN TINT | Boat Design | 17 | 09-29-2008 12:52 AM |
| Wooden Boat Rescue Foundation | jedclampit | Wooden Boat Building and Restoration | 2 | 01-16-2007 08:52 AM |
| Pourable foam, need advice | BustedKnuckle | Materials | 6 | 07-10-2006 08:19 PM |
| Self Righting Rescue Boat 15Meter for Sale | fadly2000 | Services & Employment | 2 | 07-01-2001 07:22 PM |
