Old 07-15-2005, 11:29 AM
t_baer2001 t_baer2001 is offline
need info on composite stringers
hi im new here i have a 78 27 ft sport craft that im repairing. the deck rotted out on one side and upon tearing it up i learned that the stringers in the rear of that side were rotted out also. ive been told that i would be better off to replace the stringers with composite rather than the origional wood. so i guess my first question would be where would i look for materials if i have to do it my self or where would i go/ look to order a pre made one. any help and/or info would be greatly appreciated. as i didnt expect this much work when i took on the project.
travis
Old 07-15-2005, 04:24 PM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Travis,
A few avenues to explore; there is a product called prisma-beam available, but if you need to have the top of the stringers in one plane to support the floor, then that might not work.
There are also ready-made fiberglass extrusions in various profiles available, but you must test for bondability. (some manufacturers use silicone lubricants in the extrusion process, potential kiss of death) You can also make core-foam "formers" and build a glass stringer over those, or, you can simply take a nice straight piece of wood, wax it up good, and use it as a mold to build your own hollow glass stringers.
Just a few ideas, there are many other ways to do too, just apply some imagination.
Yoke.
Old 07-17-2005, 03:22 PM
Rep: 1397 Posts: 7,215
The original setup lasted 27 years, why change it?
Anybody have info on repairing delaminated stringers? Starquesttsi Fiberglass and Composite Boat Building 5 12-16-2005 07:28 AM
Composite Design Engineer seeking employment benadeline Services & Employment 0 07-24-2005 02:38 PM
Is this progress in composite construction? Mark Peiffer Fiberglass and Composite Boat Building 16 01-13-2005 12:35 PM
More info on my design - changes too. TheFisher Boat Design 1 10-30-2003 08:13 PM
Where is the best info to learn about new composite constr? Archive Education 2 11-16-2001 10:25 AM
