Old 08-20-2010, 07:38 AM
dangtue dangtue is offline
Rep: 10 Posts: 6
Need help with inflexible boat repair
Hello everybody!
I have a Zodiac inflexible boat. Now, it has come apart in some places, and I want to repair it myself. The problem is that I don't know which kind of glue I should use. Can I use the glue which people use to join PVC water pipe?
Thanks a lot
Old 08-20-2010, 06:50 PM
Rep: 10 Posts: 6
Can anybody help me please?
Old 08-20-2010, 10:10 PM
J3 J3 is offline
Rep: 16 Posts: 60
As long as it's a post 1996 year the zodiac is likely PVC; pre 1996 and it's likely Hypalon like Avon, etc.
I've only repaired one zodiac where the tubes came off from both the transom and started coming off from the floor. I went with the genuine zodiac glue ( Zodiac #7097 Universal "Polymarine" Urethane (PVC) Glue) -- I'm not sure about using generic pvc fabric glue - the boat is worth $1000 so I want the best possible. Preparation is key - cleaning with MEK solvent wash (recommended 3 times before glue application) and have another set or couple sets of hands if possible to align everything perfectly and neatly. If it's a big area that has come apart you need to think about how you will hold/clamp/etc. it in place while it sets during the repair or you'll end up with something not right.
J3 J3 is offline
Rep: 16 Posts: 60
See http://www.allinflatables.com/support/pvc.html
Old 08-21-2010, 04:05 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,253
After cleaning/degreasing with paint thinner or gasoline, prime with Sika 206 G+P, let dry for 10 minutes, then use any polyurethane bonding compound like Sikaflex 292/295/296 to repair the separated parts.
The crucial part is using the primer, without that any attempt to repair an old inflatable is bound to fail.
Old 08-21-2010, 01:05 PM
WickedGood
Use Contact Cement! Works the best!
I have some brand new Valves for sale if you need them. Just $25 each
WickedGoodOutdoors@Maine.rrr.com
Old 08-21-2010, 01:41 PM
apex1
Ahhh,
some sales promotion maybe seen as salt in the soup, but that guy is a PITA with his free adverts...............
Old 08-22-2010, 03:05 AM
Rep: 10 Posts: 6
I appreciate J3 a lot for your information. However, I can not buy the glue you mentioned in Vietnam. I will use CDK method.
Thank CDK.
Old 08-22-2010, 03:37 AM
CDK's Avatar
CDK CDK is offline
retired engineer
You're welcome Dangtue.
The dingy I once repaired with contact cement ended in the dumpster.
Need help with boat repair Abuelo Wooden Boat Building and Restoration 1 05-04-2009 03:06 PM
repair to boat dock puddle pirate Fiberglass and Composite Boat Building 2 07-30-2008 04:05 PM
Boat repair A-white Boatbuilding 50 04-01-2008 07:04 AM
Fiberglass repair shop/ boat repair For Sale. W/ property on US1 boatguy64 Marketplace 1 03-03-2008 01:23 PM
Boat canvas repair Ssor Sailboats 7 12-23-2005 09:26 AM
