Old 12-15-2005, 07:17 PM
jfblouin's Avatar
jfblouin jfblouin is offline
Rep: 24 Posts: 163
Need advices about pourable foam
I just buy 2 parts pourable foam for my boat. My seller dont really know how to use it.
What is your suggestions?
Can I heat part A and part B up to 100F before mixing them to have better expansion?
What is the best quantity for mixing part A and B?
What kind of pot and mixing device are best for mixing?
Do you have special hints?
I'm affraid to use this product!!!
Jean-Francois Blouin
PS Sorry for my not so good english
Old 12-16-2005, 12:38 AM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
That's okay! My french is so embarassing I won't even try here.
Who makes the foam you bought? It would be easy to find out how much to mix if I knew the name.
Heating the foam is a bad idea.
Having a warm workpiece is a good idea.
Use Golves!
Don't breathe it!! Modzeee!!! DON"T BREATHE IT IN!!!! They KILL RATS with this stuff. Do it outside! It stinks!!!Like dead fish!!!
Don't get it on you!!
You can mix it in anything. You have to pour it right away anyway. I'd use a coffee can and some old soup cans.
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 12-20-2005, 09:37 AM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
In what part of the boat are you using this stuff?
You know that anything other than polystyrene foam (Styrofoam) will absorb moisture and turn into a big sponge. I wouldn't use it anyplace below the waterline! I would think hard about it's use at all, certainly NOT in any large quanitys.
There are several densitys of polyurethane (pourable) foam. none of it has a very good "flotation" to weight ratio. It adds weight, holds moisture & promotes rot & corrosion. Be careful in it's use in a marine enviroment. Darn, huh!... and it's SO damn convienent & appears to be the answer to so many design areas. NOPE, sorry.
Old 12-20-2005, 10:42 AM
Rep: 21 Posts: 504
I have seen some saturation tests with a newer urethane formulation. It looks pretty good. The saturation test was a 48hr test though.
JDF
Old 12-20-2005, 05:10 PM
ted655's Avatar
Rep: 122 Posts: 641
Lets hold good wishes for the new stuff because a "pourable" marine spec foam would be great. Sadly, I learned about this type the hard way a few years back.
Pourable foam b_rodwell Materials 39 12-18-2009 08:31 AM
Pourable foam, need advice BustedKnuckle Materials 6 07-10-2006 09:19 PM
Selecting foam core TomE Materials 14 01-07-2006 05:18 AM
building with PVC core foam signum Fiberglass and Composite Boat Building 3 11-26-2005 08:02 PM
Foam question wes_mcgee Fiberglass and Composite Boat Building 8 10-13-2005 09:16 PM
