Old 04-26-2011, 01:14 PM
Jo McKenna Jo McKenna is offline
Rep: 10 Posts: 2
Mold release alternatives?...
Hello everyone. I am brand new to posting here, but not at all new to this sight.
I have a side project as a first mold attempt. I am building an instrument pod for my hang gliding instruments and have built the plug, insuring it is a perfect fit to my vario and GPS. The mold is made from layered and glued MDF. I used body filler and spot putty to smooth out the plug and then primered with 6 coats of sandable primer.
I have since made the parting board and set the plug inside the board halfway and used modeling clay to smooth out all sharp edges. I've applied 10 coats of Mothers Carnauba Wax to the plug and parting board and this is where I hit a brick wall! I'll explain...
I live in B.C. Canada and am finding it impossible to find a PVA release agent to spray on my plug! My question is, is there a suitable alternative to PVA mold release???
Any help or suggestions would be entirely appreciated!
Thank you!
Old 04-26-2011, 01:49 PM
indianbayjoe indianbayjoe is offline
Rep: 53 Posts: 108
try pam. not perfect but i have been told it works.
Joe
Old 04-26-2011, 03:03 PM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
Im not on par with the wax you mentioned, but I usually uses ram wax on the plug/mold, about 8 coats with every successive coat polished to high gloss.
If you get PVA, do not spray on, rather use a soft sponge and gently apply in straight light strokes.
A word of warning though; make sure your polish/waxes or other materials do not contain silicon - if so, problems are guaranteed when you try to pull the mold of the plug. Also, putty, moreso body filler have a way to stick to molds, even when well waxed and PVA applied. Always good to spray a primer over before final polishing is any body filler is visible.
If using PU general purpose resin, use a polyurethane or poly-acrythane (sic) base primer for best results - based on my personal experience and never had a mold stuck to plug after using these paints as a final coat on plugs.
Hope this helps but there are more knowledgeable GRP specialists on the forum and perhaps they will be of better assistance.
Wynand
A scatterling of Africa
Old 04-26-2011, 06:16 PM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
Where in BC? there are several places to get it.
http://www.fibertek.ca/
Old 04-26-2011, 11:32 PM
Rep: 10 Posts: 2
Wow, thank you for the great relies. I managed to find Evercoat PVA release agent from Pride Marine out of Ontario Canada. Wish I would have seen the Fibertek link provided by ondarvr before ordering from Ontario, but I am very happy to have found the release agent just the same.
Now that I have to wait for the PVA to start lay-up of my molds, I will continue to work on completing more plugs and do the lay-up all at once.
Thank you all for the great advise!
Old 06-23-2011, 07:26 AM
ahender ahender is offline
Rep: 10 Posts: 46
Liquid Teflon product from Airtech.
how to remove TR mold release agent? leaky Fiberglass and Composite Boat Building 2 04-05-2011 05:16 PM
Will this shape release from mold? nautique210 Fiberglass and Composite Boat Building 6 08-05-2010 10:18 PM
Release agent and mold help Jacob J Fiberglass and Composite Boat Building 6 05-23-2010 06:46 AM
Mold Release Wax Kevinwburke Materials 4 01-26-2010 01:09 PM
Mold release wax mikereed100 Fiberglass and Composite Boat Building 11 10-06-2008 02:39 AM
