Old 02-19-2006, 06:09 PM
RSLOOP RSLOOP is offline
Rep: 10 Posts: 51
Mixed Materials and reactions
I am planing to replace some oak frames around the mast, and have composite frames in progress. The chain plates on the R-sloop are galvenized steel, mounted inboard and backed with oak backing frames. I envision to move the chain plates a little inboard and on the front surface of the newly molded frames and floors constructed in one piece.
Materials: fiberglass and carbon fiber layup
will I create a corrosive environment with this approach?
Old 02-20-2006, 04:06 PM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Correct me if I'm wrong, but isn't carbon and zinc what they use in small batteries?
Yoke.
Old 02-20-2006, 06:14 PM
Rep: 10 Posts: 51
I am sorry, but I was not clear,
The new chain plates will be stainless steel and the fasteners also. Is there any reaction in this scenario ?
Old 02-21-2006, 02:22 PM
Boatbuilder
Rep: 15 Posts: 545
I'd stick with glass. Carbon is very stiff and might cause problems when used together with softer materials. While it certainly is doable, the engineering becomes very critical. Stainless does rust a lot faster in contact with carbon.
Yoke.
Old 02-21-2006, 06:42 PM
Rep: 10 Posts: 51
Thanks for your advice, I still have time as the project will be completed next winter, this winter will see the completion of the molds.
RSLOOP
Old 02-26-2006, 10:36 AM
Rep: 1493 Posts: 7,447
Are you replacing wooden frames in a wooden boat with a rigid carbon fiber structure?
Old 02-26-2006, 01:36 PM
Rep: 10 Posts: 51
That was at the start of the project, right wow I am taking off patterns of five frames and floors. The next step will be molds the lay up frames that will continue into the floors. shaped in a "C" section to carry the metal mast step. The floor portion is anchored to the lead and the parralel frame section is bolted to the planks. new chain plates will mount on the forward face of the frame and carry on under the mast step. the frame portion will be wider than before to prevent cave-in, and there is the question which material to use. Fiberglass hand lay-up, and I felt Carbon reinforced in the middle. Please give some feed-back, or should this be not clear enough, let me know.
Old 02-26-2006, 06:52 PM
Installing a rigid structure on an older wooden boat is a recipe for disaster. It will create hard spots. These are areas of concentrated stress. Normally, with flexible structures, the stress get distributed over a large area. I recomend you replace parts with the original design and materials.
Old 02-28-2006, 07:11 PM
Rep: 10 Posts: 51
I appreciate your concern and will take it into account, when I get closer to pull the parts I will get back to this forum.
Thanks
Canting Keel reactions @ Cylinder connection!! GuestR01312011 Boat Design 7 10-30-2005 07:56 AM
materials bevan Boatbuilding 1 07-07-2005 01:16 AM
core materials gasdok007 Boat Design 0 11-11-2004 09:09 PM
Materials to use Sgray Materials 6 01-17-2003 11:47 PM
materials used Sgray Materials 4 10-31-2002 05:35 AM
