Old 04-13-2011, 05:57 PM
idkfa idkfa is offline
Rep: 66 Posts: 232
minute of silence for gel-coat
Let's have a minute of silence for "gel-coat". She served us well, was a pain in the butt to use, and for only fair scratch resistance, and SHRINKAGE...... No more......
Let's have a hand for what's next
!!!!POLYUREA!!!
Tough, non-shrinking, epoxy compatible, water impermeable!! No print-through!!!
http://www.specialty-products.com/re...ial-uses-list/
Old 04-13-2011, 06:19 PM
daiquiri's Avatar
Engineering and Design
Rep: 2574 Posts: 2,731
No word there about UV-resistance... ?
Old 04-13-2011, 06:29 PM
Steve W Steve W is offline
Rep: 360 Posts: 686
We had a customer whos business is spraying polyurea in a variety of applications, i had him apply a Bra on the front of my VW Vanagon Westphalia camper to protect it from stone chips, its doing the job much better than the ones you buy,its black and afyer a couple of years it has a kind of chalky finish much like old gelcoat which comes off when you wipe it, i probably need to wax it. Im sure there are different formulations.Im very happy with it for this application.Its a lot like spray in bedliner.
Steve.
Old 04-13-2011, 06:30 PM
CatBuilder CatBuilder is offline
Rep: 1308 Posts: 3,040
Also, this is a frightening quote from the website:
"The following list is presented to stimulate the thinking of potential users of these unique polymers. No guarantee of suitability in any specific application is implied or intended customer."
Kurt Hughes was right about this place.
Old 04-13-2011, 06:41 PM
PAR PAR is online now
Rep: 3125 Posts: 9,403
How's the cost hold up against the products it will displace?
Old 04-13-2011, 07:09 PM
Rep: 66 Posts: 232
UV- resistance is a given..sorry
It's a (relative) new product, they're still figuring out uses and testing..
cost like epoxy, 50us+/gal
The only negative I've been told is no brilliant whites, more like sand and they'll guarantee a perfect match each batch, something about the environment....and cost of Graco spray equipment. $30,000US
K5 is being used on the bottom of aluminium boats to allow running over rocks...
EPL can a applied with a brush or conventional spray equipment etc.
Old 04-13-2011, 10:45 PM
cthippo's Avatar
cthippo cthippo is offline
Rep: 452 Posts: 725
wonder if this would work for coating SOF kayaks. Probably want something more moisture tolerant with a slower setting time.
Old 04-13-2011, 11:41 PM
mark775
It fills a different niche than gelcoat. In what capacity do you work for SPI?
Old 04-14-2011, 08:35 AM
Rep: 66 Posts: 232
No I don't.
Guess when you see moulded production boats with it you'll come around.
Old 04-14-2011, 12:03 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
http://www.youtube.com/watch?v=gX6oR13qUv8 http://www.youtube.com/watch?v=Dd8-V...eature=related
Slippery when wet.
www.cheetahcat.com
Old 05-03-2011, 04:24 PM
quequen quequen is offline
Rep: 165 Posts: 113
Polyuretanic paint coat works very well over waterline, much better than gelcoat when exposed to UV, but to my knowledge, goes really bad under water. Isn't it?
Old 05-04-2011, 07:42 AM
pistnbroke's Avatar
I try
Rep: 387 Posts: 1,269
So that will be one part of the VW that wont rust ...better get the rest done....
Old 05-08-2011, 02:07 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,400
Claims by an Australian supplier - seems to be OK under water
http://www.assetsystems.com.au/poly.htm
1. Polyurea surface coatings and linings possess ultra fast cure properties which dramatically reduce shutdown times.
2. Polyureas are elastomeric products with enormous impact, tear and elongation properties suited to many high abuse applications where substrate movement can be expected. Suitable substrates include:- Steel, Concrete, Timber and Geo-membranes.
3. Polyureas are environmentally friendly with gel times of 5-20 seconds (tack free in 10-60 seconds) and very low odour. Materials are rapidly inert upon plural impingement mixing (mix at gun tip). Minimal material wastage.
4. Polyureas offer excellent resistance to thermal shock, mechanical impact, mild acids, caustic and hot water.
5. Polyureas remain flexible and provide good crack bridging qualities >3mm. Ideally suited for secondary chemical containment bunds and concrete structures holding potable water.
Old 08-28-2011, 01:47 PM
Rep: 66 Posts: 232
General chemistry and a performance comparison
Old 08-28-2011, 05:28 PM
Rep: 1729 Posts: 2,462
Originally Posted by idkfa View Post
It's a (relative) new product, they're still figuring out uses and testing................
It's been available commercially since 1950. It hasn't become very popular because it requires expensive equipment to apply and as a coating applied over a surface it has very poor wetting properties and when it does disbond it peels off in large sheets. It needs highly trained operators to apply it well.
It's also mixed with polyurethanes to make it more user friendly.
Seems there's a few manufacturers giving it another hard push recently but a new product it isn't.
Mike Johns.
gel coat,...who needs it!!!! roscoewalsh Fiberglass and Composite Boat Building 11 09-02-2009 09:33 AM
Gel coat nrodes Materials 13 01-25-2009 10:54 AM
gel coat alfiej44 Fiberglass and Composite Boat Building 10 09-05-2008 06:16 AM
gel coat instead of toolin gel ? meredog Fiberglass and Composite Boat Building 5 08-10-2006 08:53 PM
Gel coat jeremyb251 Materials 1 03-16-2006 12:40 AM
