Old 03-11-2009, 06:55 PM
DomesticPirate DomesticPirate is offline
Rep: 10 Posts: 4
Miniature CAPAC system?
Hi. My experience lies mainly in large ships. Most ships use electric cathodic protection to minimize electrolytic corrosion of the hull, along with zincs. Has anyone seen or heard of this system being adapted for use on small metal boats, aluminum boats in particular?
Old 03-11-2009, 07:06 PM
apex1
How small is small?
The megayacht industry quite often is installing them.
Old 03-12-2009, 12:39 PM
Rep: 10 Posts: 4
Good point, I was thinking of an aluminum sailboat in the 50'-60' range. I was thinking a small CAPAC system would slow the rate at which the zincs were used up, if economically feasable.
Old 03-12-2009, 10:09 PM
Ike's Avatar
Ike Ike is offline
Rep: 1256 Posts: 1,314
Mercury Marine has a cathodic Protection system that is patented, which uses electronics paired with anodes to protect their aluminum outboard and sterndrives.
Ike
New Boatbuilders Home Page
Boat Builder News Blog
My Boating Safety Blog
Old 03-12-2009, 10:26 PM
Rep: 472 Posts: 1,391
I have a 70' AL boat, I look into it and installed meters to tell me about any problems. Actual active systems can be problematic. I decide to go passive system with Zinc Chromate treatment,paint and epoxy barrier then special zincs. Active system would cause paint to peel electrons flow under paint and then you have crevice corrosion ... It is just too complicate to keep working perfectly in AL boat.
Propulsion system Anilkumar Boat Design 0 01-27-2009 06:47 AM
FORSALE Gelcoat system/Resin System cbboatworks Marketplace 1 05-04-2007 05:52 PM
New to the metric system Ron Cook Boat Design 5 03-03-2005 08:26 PM
Miniature - Speed Boat Design Choppy Boat Design 2 09-09-2004 10:53 PM
wanted: 12 meter miniature advice Guest Sailboats 2 08-27-2003 02:52 AM
