Old 05-24-2011, 01:46 AM
idham58 idham58 is offline
Rep: 10 Posts: 8
mild steel vs HTS
hello,
i'm newcomer..
just wanna to ask about the material..
between mild steel and HTS, HTS is highly resistant corrosion than mild steel.
if we have basis hip which the steel weight is around 1200 tonnes by using the HTS..
with the same design of hull and superstructure, how do i can use this data as to get the steel weight if the chosen material is mild steel grade A?
as i understood.. it need to do a scantling calculation to get the thickness of the plate..
but it seemed too tough... i'm just want to estimate only..
can somebody help me?
thanks
Old 05-24-2011, 04:14 AM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1933 Posts: 3,025
There is no difference. They both have poor corrosion properties, they are carbon steel!
Click here, as this was raised recently. It answers your questions:
Structural steel?
Old 05-24-2011, 04:33 AM
Rep: 10 Posts: 8
ok thanks for the valuable info.. then, how about the estimation on steel weight? (with only using the basis ship of 12000 tonnes of stainless steel hull)
Old 05-24-2011, 04:48 AM
Naval Architect
You'll have to design it, one with HTS and the other normal mild steel. Then you'll know the difference.
Is it possible to build in steel if not originally designed for steel? eggman918 Boat Design 16 01-17-2011 03:39 PM
Can I "mix" cor 10 with mild steel plate ? globaldude Metal Boat Building 1 06-07-2008 06:03 AM
Free of charge, Steel - polyurethane foam -Steel insulation sheets rossgiles Fiberglass and Composite Boat Building 0 03-18-2008 06:43 AM
HTS - The Future of Navy Motors - high temperature superconductor kach22i Propulsion 10 10-02-2007 08:22 AM
steel specification Michael Devlin Metal Boat Building 4 11-29-2004 07:06 PM
