Old 05-24-2008, 11:18 PM
crzhors crzhors is offline
Rep: 10 Posts: 21
Mig welding stainless tips needed
Greetings, I'd like to start doing my own Stainless welding repairs, railings,exhausts,mounts etc, anyone have suggestions on a Affordable wire feed setup to use? thanks!
Old 05-25-2008, 12:09 AM
alan white's Avatar
Rep: 590 Posts: 2,642
A good start is the Lincoln SP 135T. About $450.00, and a tank would be about $130.00 or you can rent (bad idea if you are an occasional welder).
Stainless requires a different gas from carbon steel, so if you want to do both, you're into twice the tank budget.
Stainless welds just like carbon steel with a MIG. The weld is as strong as the base metal.
Other brands are Hobart, Miller, and a few others. Stay away from cheaper rigs like Century and beware the Home Depot or Lowes Lincoln models--- they are not the same machine as is sold at welding supplies. Your best deal is actually the welding supply houses.
You can weld up to 1/4" in a single pass with the smaller welders mentioned, and multiple passes do thicker material. Most jobs are in that range.
I've made a lot of sailboat parts from stainless. Once ground and polished, they look like expensive manufactured parts.
Alan
Old 05-25-2008, 09:23 AM
Rep: 10 Posts: 21
Stainless Welding
Thanks Alan, I'm currently in a very backward area of Panama,and trying to get the machine and gas lined up. I've got lots of projects just waiting to be started.
Old 05-25-2008, 09:54 AM
northerncat northerncat is offline
Rep: 9 Posts: 162
buy a 300$ inverter tig stick welder, do your structural stuff with the stick and your pretty stuff/repairs with the tig, low cost outlay for high return all my stainles is done this way if you have more money by all means go mig
sean
Welding Astm316 Stainless Steel tevhit Boat Design 2 11-02-2007 02:17 AM
welding, power packs, mig, feeders lazeyjack Metal Boat Building 17 05-16-2007 01:05 AM
Welding stainless steel hazards SamSam Metal Boat Building 0 11-28-2006 07:10 PM
MIG welding .080 5052 aluminum sheet Jack D Davis Metal Boat Building 2 09-26-2005 10:07 PM
mig rico Marketplace 0 04-30-2005 03:01 AM
