Old 12-29-2004, 09:07 AM
Phil Locker's Avatar
Phil Locker Phil Locker is offline
Rep: 49 Posts: 84
Meranti ply specs?
Looking for the mechanical specs of Meranti plywood (specifically BS6566, but I'll take what I can get).
Elastic modulus?
Compressive strength?
Thanks
Phil
Competition Composites Inc. / Phil's Foils
www.fastcomposites.ca
Old 12-29-2004, 10:59 AM
Richard Petersen
I am very unhappy to tell you we have lived too long! British standards are no more. Search www.marineply.com. Bad news if you dig deep enough. Rich
Old 12-29-2004, 11:43 AM
Rep: 49 Posts: 84
I've dug...
Can't find what you're referring to on that site. Can you provide a link to the specific page?
Old 12-29-2004, 02:00 PM
Richard Petersen
Opening page, bottom center titled -old news and press - bottom item -BS1088:1969 dropped- read full story.
Old 12-29-2004, 02:29 PM
Rep: 49 Posts: 84
the search for specs...
I've found Sapele ply specs (BS 1088) at
http://www.worldpanel.com/Marineplywoods.htm
(scroll about half way down).
Still hoping for Meranti... anyone?
Phil
Old 12-29-2004, 03:13 PM
Richard Petersen
I can scan you a copy and Email it to you. Yes or no?
Old 12-29-2004, 03:33 PM
Rep: 49 Posts: 84
That would be great. Thanks!
Phil (email: phil at philsfoils.com)
Old 12-31-2004, 11:09 AM
Richard Petersen
What is the present status on the British Standards? Thanks, Rich
Old 01-02-2005, 08:07 AM
D'ARTOIS D'ARTOIS is offline
Rep: 311 Posts: 1,069
Meranti Ply
Meranti also known as Serayah, comes in a number of varieties ranging from Class II to Class IV.
The quality of Maranti ply depends therefore on the used type of wood.
The specific gravity of the better species of Shorea spp is around 550 kg/m3; the E-modulus is 14 ( X10 3 MpA )
The core of the Serayah is reasonable to good for many applications, the spint is useless for any purpose
Important is the type of glue used in the ply mfg process. There are too many cheap products in the market.
Is this of an help?
Old 01-02-2005, 10:17 AM
Rep: 49 Posts: 84
Yes it helps, thanks. I want to run some calculations using Meranti ply (BS 6566) as a core, and need the modulus (which you've given) and the compressive & shear strengths (still needed). Assuming any error in these numbers will be covered by using a reasonable safety factor....
Phil
Old 01-02-2005, 10:21 AM
Richard Petersen
Phil, did you get that B S info I emailed you and did you figure out what is happening to the old standards? Rich.
Old 01-02-2005, 10:28 AM
Richard Petersen
D'ARTOIS, Could you click on www.marineply.com and read all the bottom center articles about British Standards and post what has or is taking place when I buy the plywood for my next 20' with splices? Thanks, Rich
Old 01-02-2005, 11:51 AM
Meranti specs
Phil, this is what I have:
parameters are in N/mm2
Compression parallel to grain 529
Impact/Bending 0.74
E-mod 11400
Max Bending 92
kind regards
D'ARTOIS
Old 01-02-2005, 12:06 PM
BS Standard
For us, this standard is obsolete - we never trust any plywood supplier on what they claim to be or produce, no 1 lesson in boatbuilding;
Today, plywood is manufactured under different circumstances than 10-15 years ago and standard quality is not a given parameter;
Even large companies rely on what is available on the international market, regardless environmental lobbyists who have certainly speeded up the downhill
tendency of quality plywood manufacturing due to import stops on raw timber.
Factual quality testing is required for unsourced batches of plywood, regardless the qualification supplied.
Used manufacturing methods, environment and used gluetypes are of prime importance.
If you buy Bruynzeel, you buy top quality (at top prices), jus as an example.
That is sourced material, with a sourced manufacturer - with own facilities.
Old 01-02-2005, 01:36 PM
Richard Petersen
I assume that is how a 22'- 2 seat racing runabout can quickly climb in price if it is used in structural and final skin? I am planing to deal with M.L. CONDON in White Plains, N Y. As they have a full line of marine plywood and solid wood. Do you have any cautions? Thanks, Rich
What ply? Dorydog Materials 3 07-08-2005 01:07 PM
Using double layers of marine ply cat28 Materials 5 07-05-2005 01:26 PM
Australian source for teak & holly ply Willallison Materials 0 10-23-2004 06:29 PM
Where can I find sailboat specs? Vince Boat Design 4 06-07-2004 09:37 AM
New to the game. Aluminium or marine ply? mannjo Boatbuilding 6 01-04-2003 01:00 PM
