Old 01-20-2004, 03:38 PM
bevan bevan is offline
Rep: 10 Posts: 16
measurements
i've designed a 5m catamaran and want to work out how much the hulls will cost to build. measuring in weight how much resin would i need for 1m2 of that is 300 g in weight?
thankyou :D
Old 01-22-2004, 09:00 PM
Rep: 1493 Posts: 7,447
What is the weight of the cloth, how many layers and what species of wood or type or foam are you laminating over?
Old 01-24-2004, 02:35 AM
Rep: 10 Posts: 16
I ve just read a book on fibre glass, so I know a tidy bit about fibre glass, but this is the first time I've ever tried to to build a boat. I have dealt with fibre glass before but never really understead it untill now. I'm not sure about how many layers i need but i read somewhere before that with mat the amount of resin needed is 1.5 x the weight of the mat and with cloth the amount of resin need is 2 x the weight of cloth. Is this true??
Old 01-24-2004, 09:30 AM
The ratio of resin to fibers is higher with mat. If you have no experience with fiberglass, there are two options. One is to pay a designer to do the calculations or use an existing design. The other is to build to your own design, but expect to fix and modify it. I am curious, if you designed a catamaran, how did you calculate the scantlings and structure without knowing the characteristics of fiberglass?
10M Thai Long Tail S.E.A. Post-Tsunami 44 06-20-2009 11:00 PM
Design help, making a tunnel clamsalot Powerboats 22 03-03-2008 10:11 PM
Mile Measurements....... Wynand N Sailboats 1 12-18-2004 05:13 PM
boat design software Jamesey01 Metal Boat Building 9 11-14-2004 09:03 AM
Board Measurements SeaBird Boat Design 0 10-19-2003 04:09 PM
