Old 09-03-2011, 05:26 PM
cthippo's Avatar
cthippo cthippo is offline
Rep: 452 Posts: 725
Materials for whitewater kayak
Can anyone think of an alternative to plastic that could be used to build a whitewater kayak?
The problem, of course, is durability. whitewater b oats get launched off waterfalls, bounced into rocks at high velocity, and generally take massive amounts of abuse. All the WW boats I've seen have been plastic because you can't break tupperware. The flip side of that is they don't build these boats in size extra-fat-ass and I don't have a roto-molding machine to build my own. Is there any other material that might be able to survive and can be worked with at home?
Aluminum welding is like sex. The first few times you had at it, you probably could barely please yourself, but with practice and some guidance, you managed to impress one or two prom dates. ~PAR
Old 09-03-2011, 06:21 PM
rasorinc rasorinc is offline
Rep: 687 Posts: 1,175
Wood with fiberglass over. This is not a whitewater kayak but the materials list will give you an idea. http://www.glen-l.com/designs/canu-r...kayak-bom.html They have other kayak plans. When I say fiberglass I mean a product like Dynel or Xynole which protect from rocks. You would probably have to use a hard wood for a skeletal structure with ply over.
Old 09-03-2011, 06:42 PM
Stumble Stumble is offline
Rep: 604 Posts: 1,086
I was thinking Kevlar which has pretty high abrasion resistance. Perhaps dyneema (I don't know of a boat build with it) which has extraordinarily high abrasion resistance.
Old 09-04-2011, 09:06 PM
LP's Avatar
LP LP is offline
Rep: 385 Posts: 671
I've been pondering this myself as I have been on a bit of a kayak developement kick.
Here is a thread on Dynel.
Dynel vs. Fiberglass - as wood strip sheathing
Some of Paul's wisedom on fabrics.
Recoating in Dynel
A thread from a kayak forum talking about sheathing and hull material.
http://www.kayakforum.com/cgi-bin/Bu...mes/read/18311
It sounds like a double bladed sword. Puncture resistance and abrasion resistance. Dynel on the lower exterior for abrasion over a base laminate of s-glass (less expensive) or kevlar (more expensive). I would be tempted to apply a less rigid interior sheathing to the lower surfaces to back-up and support wood/ply core during impacts. Sounds like dynel has a weight penalty so it's use may be best reserved for the lower exterior shell with a glass sheathing on the inside. FWIW.
And one more link that might take you to another resource at Gougeon Bros. Post #5
http://forum.woodenboat.com/showthre...-over-ply-deck
LP
God bless the open minded people of the world. LP
Old 09-06-2011, 05:52 AM
latman latman is offline
Rep: 14 Posts: 48
a high ductility fibre like Kevlar , Innegra or Dyneema laminated with epoxy resin , leave it out in the sun for a rough post cure.
Old 09-10-2011, 04:04 PM
cthippo's Avatar
Rep: 452 Posts: 725
The issue, as I see it anyway, is impact resistance and the ability to return to it's previous shape after an impact. Abrasion resistance is also important, but it's the impacts that are going to break things. Be interesting to try though!
Basically, watch the video and then design a non-plastic boat that can survive that.
Old 09-10-2011, 07:23 PM
Build the internal structure out of # 1 Hickory. Someone else will have to suggest fiber glass materials.
http://www.connectedlines.com/wood/wood31.htm
kayak mould for sale and kayaks for sale new kayak for sale canoe for sale joseph sigley Boat Molds 2 04-09-2012 06:28 AM
Whitewater Madness Ravencrew Powerboats 4 10-14-2009 01:13 AM
whitewater molds sdowns Boat Molds 0 09-28-2009 10:56 AM
Whitewater Jetboat Racing (Ever heard of it?) Ravencrew Open Discussion: All Things Boats & Boating 8 02-11-2008 07:27 PM
small drift boat for fishing/whitewater angel Wooden Boat Building and Restoration 2 07-01-2004 11:52 PM
