Old 04-14-2005, 04:47 PM
fcfc fcfc is offline
Rep: 333 Posts: 680
Materials for decks and superstructures ???
Plan calls for a 3 layer 1/4 marine plywood. Molded in place.
Alternative design for the roof is balsa cored fiberglass. deck still in plywood.
At least for roof tops and sides, I find this heavy.
What would be the problems of a cored contruction, say inner / outer layer 1/4 (or thinner) marine plywood, core 1/2 (or thicker) end grain balsa.
Of coure core replaced by real wood at all fixation points.
A kind of molded in place balsa core plywood (baslalin, balsamarine etc ...)
Thanks.
Old 04-15-2005, 05:00 AM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Sure, an end grain balsa-cored panel is actually stiffer than a plywood-cored one, due to the better fiber orientation.
Yokebutt.
Old 04-15-2005, 09:25 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
I don't know your boat, but maybe the deck need that strength globally even if a sandwich will be more than stiff enough locally. The deck has to have almost the same global strength properties as the keel+bottom.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
