Old 03-19-2008, 08:24 AM
Steve W Steve W is offline
Rep: 315 Posts: 638
mast tabanacle
I am trying to find an off the shelf mast tabanacle to use on a ranger 26 sailboat.All i have been able to come up with so far is the one made by Kenyon which is like two channel sections nested with horizontal hinge pins allowing the mast to be raised from either direction.Unfortunatlly this type is 1 inch thick and may not be able to used due to shroud length.So,what im looking for is the type which has a piece up each side of the mast with a slotted hole for a 1/2" pin thru the mast,this type only has about 1/8" under the mast which can be tolerated by the existing shrouds.I have one of these on a 25' boat i built 20 yrs ago but dont remember where i bought it.Any help locating a scource would be much appreciated.
Steve.
Old 03-19-2008, 09:42 PM
charmc charmc is offline
Rep: 833 Posts: 2,390
The Kenyon tabernacle sounds like a good design. Your turnbuckles should allow for a 1" change in height without any problem. If not, replacement 316 SS turnbuckles suitable for a 25' boat run from $75 to less than $25/ea. Shroud adjuster plates cost even less. Either will allow adjustment over a range of at least 2 1/2" - 3 1/2".
Best,
Charlie
Old 03-20-2008, 08:23 PM
alan white's Avatar
alan white alan white is online now
Rep: 1168 Posts: 3,270
Yes, I'd play with the rigging rather than let the search for a shorter tabernacle become a problem. Also, you can cut the mast if the design allows.
If you cut the mast the inner casting would need to be reinserted 1" higher, so make sure the old screw/rivet holes won't interfere.
Alan
Old 03-20-2008, 10:38 PM
Rep: 315 Posts: 638
Thanks guys,i think i will just go with the kenyon base and cut the appropriate amount off the mast as suggested.
Steve.
The all-in-one Mast katfish Sailboats 10 04-16-2010 08:45 PM
MAst ryansemail707 Wooden Boat Building and Restoration 14 08-01-2007 06:59 PM
Sleeving a mast jedkins Boatbuilding 3 08-26-2006 11:31 AM
mast design-how do you go upon calculating the effect of the sail on the mast??? airturb Sailboats 34 02-21-2005 10:55 AM
mast dobsondwd Sailboats 6 08-29-2004 09:52 AM
