Old 11-18-2005, 11:51 PM
mariner 40 mariner 40 is offline
Rep: 11 Posts: 59
Mariner 40 deck and cabin replacement
Hello
I have read articals here where it was suggested to use a softwood inner layer, plywood, glass, then teak. Is there anywhere I might find detailed instruction on this process? Thanks
Old 11-20-2005, 09:41 PM
Rep: 1397 Posts: 7,216
What are you building?
Old 11-20-2005, 10:17 PM
Rep: 11 Posts: 59
Sorry, my wife has been reading my mind for so many years, I though everybody would know also. I am replacing the deck and cabin on a mariner 40 ketch.
Old 11-25-2005, 06:50 AM
Rep: 700 Posts: 3,208
To remove the declk to get out the rotten plywood in not necessary.
With a new deck the stink of the rotten wood will eventually go away.
Strip off all the deck fittings and pull the teak deck & dispose of it.
Get a 1220V-10A or larger grinder , a Bher Manning flat foam pad and VERY coarse paper used by the floor refinishing industry.
This comes in rolls or sheets and should be cut or snapped into squares.(the corners keep you from digging in and creating unfairnesses.
NAPA has a removable rubber cement known as DISC ADHEASIVE
Use this combo to completly sand clean a section of dead deck.
Notch Trowel filled epoxy onto the deck and with weights or a vacume cleaner pull a foam or cleegcell type sandwich material to the deck.
When all covered with foam , simply glass the top with polly resin to about 1/4 or 3/8 at the anchor handling area.
No skid of your choice and you have a deck thats insulated 4X as stiff , and wont suffer from not rebeding deck fittings often enough .
Works for me,, but it IS messy & labor intensive.
FAST FRED
Old 11-25-2005, 06:22 PM
A sure way of doing it right, is to copy the old construction. It lasted for quite a while. There are some materials, like epoxies and sealants that can be combined for even more durability.
Old 12-01-2005, 08:11 PM
Rep: 11 Posts: 59
Hello
Some of the floor and deck stringers need replaced on my Mariner 40. I live in Kentucky. What would be the best wood to use to replace the stringers, and then what is most practical? Thanks for any help on this.
Old 12-01-2005, 10:24 PM
glassman glassman is offline
Rep: 15 Posts: 36
putting a new deck over the old, not the way the wet and roted wood will dry but also go to dust ,and if it had teak sole save it tossing it like Fast Fred said that a wast of dollers and good wood . Gonzo is right and with epoxy and new materials on the market it will last
Old 12-02-2005, 11:16 AM
nero nero is offline
Rep: 112 Posts: 624
Look at sasafrass and ash. You can use yellow cypress also.
Old 12-07-2005, 09:21 PM
Rep: 11 Posts: 59
Hello
The original deck and cabin plywood is 1". Would it hurt to use 3/4" instead?
Old 12-08-2005, 01:19 AM
It would be about half as stiff. You could laminate two 1/2" with the seams staggered.
Old 12-08-2005, 06:21 AM
"The original deck and cabin plywood is 1"."
What caused the rot is the lack of maint to every penitration that goes thru the GRP into the ply.
AS hidden screws are impossable to routenly service , a copy if the old deck will leave at about the same speed.
Newer sealants are better than decades old stuff , but die as well a year or two later.
YOU have to decide if you can accept the short service life of glass over ply.
The cost of doing it "better" is quite low , just different skill sets.
FAST FRED
Old 12-08-2005, 09:20 AM
Sealants last decades. Lifecaulk, for example, is still pliable and adhered to wood and metal after 30+ years.
Fast Fred: where do you get you data from?
Old 12-08-2005, 10:30 AM
Rep: 11 Posts: 59
Thanks for the info. Fast Fred, what would be a better fix? I am not in a good area of the country for sailboat repair experience. The carpenters here that I have talked to wants to use area woods for repiar. I don't want to be in a storm on my top and wished I had done something else! Once I have determined the method of repiar. I will get a carpenter to make repiars.
Old 12-10-2005, 06:17 AM
Get a book on construction from Airex and from the other cheaper folks like www.nadia-core.com.
You will need someone familiar with fiberglassing , rather than a carpenter.
AS sugested a relartivly simple solution for a starting glasser =
FAST FRED
fiberglassing plywood boat deck KMD Materials 11 11-10-2005 12:49 AM
Boat Stability help pls. trouty Boat Design 11 10-28-2005 11:55 PM
Easier way for balsa core deck replacement? pago cruiser Boatbuilding 4 06-01-2005 07:20 PM
255' Three-Masted Steel Barkentine for sale Yachting Marketplace 0 02-09-2005 10:35 PM
