Old 12-04-2004, 08:35 PM
matt in miami matt in miami is offline
Rep: 10 Posts: 3
marine putty
hi ...Am rebuilding a kayak epoxied it and shaped it fairly well and then went to put a little coating of marine putty on it. Now Im sanding it with a 60 grit and man it takes forever.what is the best sandpaper you would se to get this stuff knocked down? Im used ot welding metal the grind then glass then a touch of bondo on the final shaping . This stuff is like rubber. thanks..
Old 01-05-2005, 11:04 AM
Laoch Laoch is offline
Rep: 10 Posts: 4
marine putty
I found 3m paper to be very effective at cutting through the gunk. I had to sand epoxy primer for months, literally like rubber, with 60 grit. It went on with a roller and looked like garbage, very thick even after being thinned to its max. I actually went with 34 grit above the water line to get it back to a uniform surface, then 60 grit and had to go back and putty like crazy in between sanding grits. I'm restoring a 30 ft. racing sailboat. Try using west system epoxy and add the fairing compound either 407 or 410. It's an ultralight microballoon that eases sandability. 410 is the lightest and good for large areas like your hull. I've been using 407 for the pinholes, pitting, and 34 grit scratches. Another tip: Through this expereince of sanding for months (large hull area) I found that changing the sandpaper from the sander and or block frequently makes the process go faster and you are less likely to burn out the sander and your arm. I just mixed up some west system putty thinnly as a glaze to get in the imperfections i did not see before on top of the base coat (dark blue) using a felxible card that comes in credit card junk mail. Now I am wet sanding with 220. I do a 2'x2' section then I change paper off the block. Plus I add dish detergent to the water in the bucket and let the paper soak for 15 min. for added felxibility. I will do a 320 wetsand after 220 and then 2 more base coats wetsanding with 320 inbetween and 600 on the final base coat before the clear coats. Hope this helps. Good luck.
Old 01-05-2005, 01:20 PM
Rep: 2891 Posts: 8,795
I'd avoid using West System 410 only as the filler, it's difficult to flow out onto the surface smoothly, requiring additional fairing. Mix about 50-50 406 in with the micro balloons and the smoothing will be much easier. I use 407 for fairing as it's much easier to get a reasonably smooth coating with an applicator.
Change paper often, it does speed things up. I like 3M, but have had better luck with Norton's 3X brand. It has a cloth backing, so it doesn't tear easily and the abrasive is well stuck to the backing, plus it seems to last longer then other brands. It costs more, but this is typical of quality products.
Old 01-07-2005, 04:34 PM
Rep: 10 Posts: 3
thaks for the response micro balloons it will be then..
Westlawn School JCFARER Education 59 08-26-2006 07:34 PM
MISSION MARINE Looking For a Few Good People Mission Marine Services & Employment 0 11-15-2004 09:09 AM
mahogany marine plywood structure? blackspot Materials 13 10-06-2004 09:39 AM
Using EFI and marine setup vs. car setup curtis73 Powerboats 6 03-18-2002 01:45 PM
