Old 11-24-2005, 09:08 PM
cyclops cyclops is offline
Rep: 29 Posts: 1,059
Which marine plywood?
A good supplier near me has the following. From best to worst, please rate them for the following applications. I have a good cabinet maker who will do the cutting of the scarf angles. All 1/4". Some will be 10'--12'--16'. Ash, White, quartered A1---------Mahogany, Honduras, flat cut A1---------Mahogany, Philippine, Ribbon Stripe A1--------Same, but rotary cut-----------------Mahogany,Occume (Morroco). ---------------These will be used for the bottom skins with frames and stringers forming 12" x 12" boxes on the bottom. All edges will also have 1" x 1" triangular gussets glued from the edges to the bottom skins.----------------Side frames are 12" apart. They will also have 1" triangular gussetts glued for support full length. Engine floor same. Main deck same. I am sure the boat structure will survive a roll with ease. ------------ The boat is 20' x 4.0' @ WL and 5' at the deck x 3.5' deep at the bow, with a reverse sheer. Transom is 2.5' deep. I can scan the plans to someone if they know how to post them. Thanks for any help at this point of the construction.
Old 11-24-2005, 09:16 PM
It is a 2 seat runabout, probably 800# of hull. 700# of engine. 300# of V drive equipment. 100# of "stuff". and 180# of gasoline. A Gentleman's Racer.
Old 11-25-2005, 04:41 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Shelman makes a very good Okoume plywood, BS1088, Lloyds serticate, 15 or 25 years warranty, fungicide in the glue.
Se this discussion, Shelmarine vs Bruynzeel:
http://www.woodenboat-ubb.com/cgi-bi...=1&t=010227&p=
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Westlawn School JCFARER Education 59 08-26-2006 07:34 PM
wanted: marine plywood snapper340 Marketplace 9 12-06-2005 09:00 AM
fiberglassing plywood boat deck KMD Materials 11 11-10-2005 12:49 AM
Sealing Marine Ply Decking CrankyCrankPot Materials 5 10-25-2005 05:37 PM
mahogany marine plywood structure? blackspot Materials 13 10-06-2004 09:39 AM
