| marine grade fir I am currently getting prices on ply for a planing boat (flats power boat) the boat will be 20' with a finished weight of 420 lbs. it's max HP is rate for a 50 it is also has a pocket drive hull. I found 2 good sources locally for Marine Fir and wanted some input on using this material versus meranti 1088 or 6566. It will be built basic stitch and glue with 2 layers of 12 oz. on the bottom pannel and one layer of 12 oz. inside. Just wonder if the 9mm marine fir would be a good choice, any sugestion and/or comments would be appreciated..... Flatscat |
| Marine grades will all have similar standards, though Douglas fur has finishing issues, but this isn't a problem if you intend to sheath her with 'glass. Considering the heavy 'glass sheathing you've suggested, 9 mm will be fine. Go for it . . . |
| thank you for your reply, |
| AM/FM?CD Player Marine Grade? | heyblmyers | Open Discussion: All Things Boats & Boating | 4 | 07-10-2007 12:10 AM |
| Marine AM/FM/CD PLAYER DO you need marine grade? | heyblmyers | OnBoard Electronics & Controls | 2 | 07-07-2007 02:39 AM |
| Price of Marine Grade Steel in Asia | mattplowman | Metal Boat Building | 13 | 05-03-2007 06:21 AM |
| Steel Plate - Marine Grade in Asia | mattplowman | Materials | 0 | 05-03-2007 02:36 AM |
| is marine grade ply needed? | Nathan.S | Materials | 5 | 04-11-2007 08:13 AM |
