Old 01-07-2007, 05:39 PM
etott etott is offline
Rep: 10 Posts: 19
Making a hot wire foam cutter.
Anyone make a hot wire foam cutter?
I have an AC electric burner/heater kind of like an electric stove, and was wondering if I could make one from that?
Old 01-07-2007, 08:00 PM
SamSam SamSam is online now
Rep: 464 Posts: 1,608
If you google 'hot wire foam cutter', there are 1,070,000 hits with most of the first ones telling you how to make one. What are you going to use it for? Sam
Old 01-08-2007, 10:27 AM
Rep: 10 Posts: 19
I wanted to use it for cutting 2" insulation foam for building a plug.
Would the electric burner work if I used the correct resistance wire?
Thanks
Old 01-08-2007, 12:04 PM
rayk's Avatar
rayk rayk is offline
Rep: 146 Posts: 297
Try using 12v and appropriate resistance wire for battery amperage.
Safer and same effect.
Buy new resistance wire too.
Old 01-08-2007, 05:33 PM
Here's one of those google sites. There are a lot more. At the bottom of this one there are links to 5 home built versions. Like rayk says, don't use 120 volt AC, it's too dangerous.
http://en.wikipedia.org/wiki/Hot-wire_foam_cutter
How will you use it making a plug? Will you use it freehand or will it follow a pattern? Sam
Old 01-11-2007, 07:45 PM
Blue Heron Blue Heron is offline
Rep: 10 Posts: 19
I agree. I used a 12V electric train transformer for mine. The built-in rheostat is useful for controlling temperature.
Old 03-08-2007, 09:42 AM
thill thill is offline
Rep: 10 Posts: 36
1. Buy a roll of the thickest tungsten filament wire (can't remember the diameter) from an electrical supply store.
2. Make a "bow" out of wood. (C-shaped)
3. Put a power cord on a regular light dimmer, and mount to the bow. Run output wires to the ends of the bow.
4. String the bow with the tungsten wire and connect ends to the power wires.
To use, turn the dimmer all the way down. Plug the dimmer in and slowly turn up the dimmer until the wire begins to glow faintly. Too hot, and the wire will break. Cut to your heart's content.
Hot wire is the only way to cut foam.
-TH
Old 03-13-2007, 12:31 AM
mike1 mike1 is offline
Rep: 23 Posts: 54
I Have a CNc foam cutter that I have used for cutting sections for a plug. A hand held bow with wire probably wont work , youd need a template to run the wire over.
Old 03-13-2007, 12:56 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1528 Posts: 5,518
What kind of foam are we talking about? The sickly yellow eurothane stuff or the seat stuff.
I need to cut some foam in the near future,-- the eurothane stuff
Old 03-13-2007, 09:39 PM
Rep: 23 Posts: 54
Jack,The foam that I can cut is Polystyrene , either expanded or extruded.
Polyeurothane cannot be cut with a hotwire, and I believe gives off noxious fumes if you try to.
I have seen some ridgid poly eurothane cuting done with a cnc machine that uses a flexable toothed thin wire ,The machines are expenseive , but there might be and organisation near you who would do the cutting for you.
My CNC machine I made myself for very little $
Mike
Old 03-13-2007, 11:52 PM
Frosty's Avatar
Mike1 Oh- well thanks for that then, back to the bread knife.
Old 03-14-2007, 04:01 PM
alaskamokaiman alaskamokaiman is offline
Rep: 13 Posts: 59
You can put some tape on the base of a band saw and cut poly. You have to stop it from going down the hole on either side of the blade then it cuts nice. I made many costumes this way.
Old 03-29-2007, 02:25 PM
joefaber joefaber is offline
Rep: 10 Posts: 17
electric carving knife?
blades are eight to twelve inches long.
reciprocating cutting action is designed for cutting meat, solid foam shouldn't be a problem.
draw the pattern on the board and proceed to cut outside the lines.
Hot Tub In A Boat rhubley Boat Design 26 05-03-2007 04:37 PM
Mercuiser 165 Stops When Hot GZT Gas Engines 3 12-16-2006 02:48 AM
Engine too hot seagums Gas Engines 5 08-09-2006 01:02 AM
Hot zinc spray? Wynand N Metal Boat Building 14 01-30-2006 02:13 AM
Hot Water Heater ORION1 Sailboats 8 08-15-2005 08:00 AM
