Old 09-19-2006, 11:32 PM
Vince Hosea Vince Hosea is offline
Rep: 10 Posts: 13
Main shaft rebuild with Duralloy
I am rebuilding an Allgire Z drive unit and the main shaft is wore out at the seal areas. Am trying to rebuild up the worn area with this composite Duralloy and remachine. Just experimenting. Not sure how it will turn out, esp. after I have to press a ring gear on. Anyone tried it?
Old 09-19-2006, 11:41 PM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1528 Posts: 5,518
I havent personally, but I have unsuccesfully tried all kinds of things to repair stuff in the past.
After you push on the gear could you then push on a bush over the worn part and fit a larger seal?
Old 09-27-2006, 12:48 AM
Rep: 10 Posts: 13
Well the results are in. Built up the worn area where the ring gear goes on the shaft, machined down the Duralloy, installed the gear (heated to about 200 deg F. & is .002" interference fit), removed gear three days later and the stuff held up and stayed on the shaft. So far so good. We'll see how it does after sitting in gear oil for a year or so.
As far as the seal area goes, I suppose it is possible to sleeve the shaft but the machining gets tricky as the area in question leads immediately into the prop taper area. The seals are one of a kind. They are called a "syntron seal," they only come in one size and are shaped sort of like a cone (they are also $150.00 ea.). I wind up removing and overhauling these drive units every 9-14 months. The tugs they are in see excessive use (2000 - 3000 hrs/year). So time will tell.
It is the old cost effectiveness thing that is driving this. This is the lowest cost repair method. New shafts are a couple grand and 6 to 12 months out, and having a real inside machinist and shop do this isn't much cheaper (I'm a diesel mechanic with basic lathe skills). I have heard of something called "flame spraying" where you build up the worn area with like metal and remachine. I would like to try that but the boss gave me this stuff.
Vince
is it a short shaft or long shaft? donell67 Outboards 2 03-14-2007 12:07 AM
long shaft or short shaft Bill Kubiak Powerboats 17 05-26-2006 01:00 PM
short shaft motor on long shaft boat ohenry Boat Design 0 03-21-2005 09:02 PM
20 ft aquasport rebuild Brad Morgan Boatbuilding 1 05-26-2004 08:42 AM
Help with rebuild PsyWarrior Boatbuilding 0 09-06-2002 11:14 AM
