Old 03-16-2004, 10:26 AM
Matthew Matthew is offline
Registered
Rep: 10 Posts: 40
Low cost Carbon spars
Hello,
Does anyone know where I might be able to obtain low (ish) cost Carbon Fibre tubes, with and without tapers. We are in the UK, but I had heard about low cost CF spars coming from Eastern Europe? Anyone Know anything?
Regards
Matt
Mat Newland
Old 03-16-2004, 11:30 AM
Rep: 2891 Posts: 8,796
Describe "lowish" as the wish for high tech materials, usually requires substantial funds over a more conventional approach. Cutting costs is everyone's concern, but I'm reminded of the TI-99 calculator I bought many years ago, when they appeared as the first on the market of the type. I paid over a hundred bucks for the thing, which now can be had under $15. The high tech machine then was in demand and required techniques and materials that weren't in big supply, hence the high cost (typical of cutting edge stuff) Now after 30 plus years of production, well established material, labor, distribution, sales, etc. networks have made the product very affordable. The same will be true of CF sticks some day.
Old 03-16-2004, 04:11 PM
betelgeuserdude betelgeuserdude is offline
Registered
Rep: 10 Posts: 62
Depending on your requirements, and how well tooled up you are, you may be able to make your own, utilizing unidirectional and braided carbon sleeves on a tapered mandrel.
http://braider.com/index_lo.html
A&P Technology, Inc.
I too am interested in any sources for mass produced carbon fiber tubes, particularly here in the States.
DC
Old 03-16-2004, 05:34 PM
grob's Avatar
grob grob is offline
Rep: 53 Posts: 211
Matt,
My experience is:-
In the UK the best price for prepreg tube I have found is www.carbonfibretubes.co.uk
If you don't mind pullwound then www.fibreforce.co.uk are cheaper still. But you may need to buy large quantities.
also tube should be fairly easy to DIY.
In summary for 3" OD 2mm wall
wrapped prepreg ~£40/m
pullwound ~£25/m
DIY ~£15/m
Please let me know how you get on with your search.
All the best
Gareth
www.fourhulls.com
Old 03-17-2004, 02:33 AM
henrikb's Avatar
henrikb henrikb is offline
Rep: 116 Posts: 112
Check this site:
http://www.exelindustry.net/tubesand...bes60-200#list
Henrik Borg
Builder of the IMS33 R/C
http://web.telia.com/~u21114029/
Old 03-17-2004, 03:57 AM
Registered
Rep: 10 Posts: 40
What is the difference between pullwound and wrapped pre preg?
How are they manufactured?
Thanks for all your help on this - anyone any other ideas?
Matt
Mat Newland
Old 03-17-2004, 07:33 AM
quicksail quicksail is offline
Rep: 25 Posts: 58
www.compotech.com
Section available and prices.
Old 03-31-2004, 10:51 AM
Anthony DeLima Anthony DeLima is offline
Rep: 10 Posts: 8
Matt:
I know we are over th epond but your pound has a lot of purchas power here. We manufacture axially weighted carbon tubing utilizing a digital 3 axis braider in line with a filament winder to produce streight, streight to taper and tapered tubes under 6" in diameter. We can drop plies on the fly and lots of other fancy tricks. Shipping to the UK is not as costly as you may think (ie we have available Flying Dutchman spars delivered in the UK for 1200$ US all in). We have mandrells from .375"-6" streight and streight to taper along with some D sections and wing sections. You can take a closer look at the sections available and the $/ft on our web site www.forterts.com if you do not see what you are looking for ping us back and we willpunch out a quick design for you.
Thanks Tony
Old 04-02-2004, 06:39 AM
grob's Avatar
Rep: 53 Posts: 211
Originally Posted by Anthony DeLima
Matt:
Thanks Tony
If its products are as good as its customer service, this company should be brilliant! The quickest most helpfull quote I have ever received.
Old 04-05-2004, 09:17 AM
Rep: 10 Posts: 8
Thanks for the complement
Thanks for the complement we are a small company and try to focus on what we do best.
Tony
Old 05-04-2004, 07:12 AM
National3434 National3434 is offline
Registered
Rep: 10 Posts: 29
Matt
Good explanation at http://www.fibreforce.co.uk/process.htm.
Supplies of dinghy spar sized tube in the UK (not tapered though) www.woolmer.co.uk. In 3m lengths. Currently building a Moth mast with 2 of their tubes. Not tested yet though!
Cheers
Tom Edom
N3434
Old 05-07-2004, 03:07 AM
matthewuk matthewuk is offline
Rep: 10 Posts: 4
We use carbonfibretubes.co.uk
They manufacture to our spec at a reasonable price.
Cant say fairer than that.
However If you need greater volumes, go abroad.............
Jinli Composites in china or one of the Taiwanese producers
What size tubes were you after.... we might have some.
Best Free or Low Cost Marine Design Software? (2001-2005) Admin Software 52 01-01-2006 12:40 AM
carbon spars from china or far east?? Pavook Sailboats 5 06-04-2005 07:58 AM
Low cost composite materials danielro Materials 5 03-12-2004 02:16 AM
carbon monoxide boating deaths Guest Open Discussion: All Things Boats & Boating 7 10-28-2003 09:51 PM
low cost CNC? WPLANE Boat Design 9 09-09-2002 10:17 PM
