Old 10-30-2008, 05:38 PM
awol46 awol46 is offline
gatorbait
Rep: 10 Posts: 19
looking for ply for stern
I am searching for some 12 x 5 sheets to finish the stern of a 33 ft cavalier. I want to use ply verses plank due to cost. I was told it is available but am having trouble locating some. Please help !!!!!! I want to use one sheet so the grain is consistent and there is no seam showing in the finished project. Also needs to be good quality with good color veneer finish fo staining.
Old 10-31-2008, 06:14 PM
grady's Avatar
grady grady is offline
Novice
Rep: 70 Posts: 459
Plyed
Hi 5x10 was the largest sheet on their web site, but call I'm sure they can help. they're a great resource.
www.boulterplywood.com
Hope this helps
Grady
Fair winds & calm seas
Old 10-31-2008, 10:03 PM
Rep: 2891 Posts: 8,795
You can order custom size plywood from most manufactures, but it's going to be scarfed to length and you'll pay twice as much as regular size sheets. You can scarf them yourself, though I'd be very surprised if you could install a single sheet of plywood that size. Jacking, bracing and insuring good contact on a sheet that size takes considerable planning and man power. You'll be better off working with manageable sizes. Yep, you'll have a few seams, but so does the other portions of your boat. Also make sure the plywood is at least the same thickness as the planking it is replacing, because plywood isn't a strong longitudinally as solid lumber.
Is there validity to the notion that a pointy stern, a canoe stern, is safer at sea saltydog123 Sailboats 27 04-01-2009 04:20 AM
covering ply lorri Wooden Boat Building and Restoration 7 09-23-2007 12:21 AM
Stern shape design for surface drive/stern drive Alik Boat Design 8 06-15-2006 08:36 PM
What ply? Dorydog Materials 3 07-08-2005 01:07 PM
absolute beginner ply/epoxy or ply/glass wannabe Materials 9 08-13-2004 06:01 AM
