Old 03-23-2011, 07:00 PM
Vulkyn's Avatar
Vulkyn Vulkyn is offline
Rep: 529 Posts: 486
Local epoxy advice
Well started some tests (yes FINALLY after almost a year!!) with epoxy... have to say it was a joy trying it out for the first time.
Due to current conditions in Egypt and the lack of any sort of money, i started playing around with local epoxy brands instead of going for something like west system.
I coated some wood and made a small bonding trial and the results where acceptable. The bonding strength is good as far as i can tell which means i will need to do some more comprehensive tests.
The epoxy has a loooong curing time though after 4-5 hrs it was just starting to get less viscous (could be i did not mix portions properly) but according to the data sheet it need 8 hrs setting time.
For the time being i attached the technical data sheet of the epoxy i tried as i would love to get some advice regarding it.
The supplier has no clue regarding the epoxy in marine use nor fillers to get the epoxy into a peanut butter consistency for bonding.
Here is the company's web site as well .. http://www.cmbegypt.com/en/index.php?page=epoxy-filler
The Mummies Dummy guide to boat building stuff!!!
"All of us could take a lesson from the weather. It pays no attention to criticism."
"Learn wisdom when you can its gona help you out some day in your life"
Old 03-23-2011, 08:36 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
The mix is 2:1 by weight! Did you use a scale?
Slippery when wet.
www.cheetahcat.com
Old 03-24-2011, 12:48 AM
Vulkyn's Avatar
Rep: 529 Posts: 486
No but i am getting one soon .....
According to the data sheet, Is it a viable option for boat building?
Old 03-24-2011, 09:37 AM
Herman's Avatar
Herman Herman is online now
Resininfusion.info
Rep: 1043 Posts: 1,269
For what I read of it, this stuff can be used for epoxy/wood boat building. Just the heat resistance, I doubt that it is that high, but even it it was just 45 degrees C, it would not be that big of a problem.
Get yourself a good scale, that is important.
Old 03-24-2011, 10:16 AM
Vulkyn's Avatar
Rep: 529 Posts: 486
Thx ! Yah I will I took some pictures that I will post later today on my first epoxy trials. I am also waiting for the data sheet for the filler which I have not used yet.
Need Advice about Epoxy and cloth -mistake Capt Ram Materials 10 02-12-2011 11:26 AM
Pirates are local heroes Manie B Open Discussion: All Things Boats & Boating 36 11-27-2009 05:04 PM
Glue/epoxy advice. ROUGE Wooden Boat Building and Restoration 8 12-30-2007 08:50 AM
advice on epoxy and polyester craigathome Fiberglass and Composite Boat Building 2 02-20-2006 10:04 PM
local interpolation redcoopers Software 2 08-13-2004 10:43 AM
