Old 10-31-2011, 09:49 PM
redreuben redreuben is offline
redreuben
Rep: 164 Posts: 352
Light Weight Plywood
Hi all,
I have been looking at ply for a multihull build, most likely a Crowther Buccaneer Tri, the benchmark seems to be the Joubert Gaboon, but I am wondering what are your thoughts on this stuff ? It would appear to be about 20% lighter again.
Goldcore Light: Quality Lightweight Plywood. Plywood for Marine, Motor homes, Construction and Commercial interiors.
Assume all exterior surfaces to be sheathed in epoxy and 4oz S glass.
Cheers,
RR
Old 11-01-2011, 12:37 AM
PAR PAR is online now
Rep: 3125 Posts: 9,403
There are hundreds of brand name plywood products world wide. Can you offer a spec sheet or PDF for this product? This product was discussed earlier this year, but no speices information was available then from Goldcorelight.com.
Some communications with industry insiders has revealed it's 1 mm Ocoume faces with inner cores of Alstonia. It has low resistance to shock loads and poor stiffness. It's been designed as a substrate for cabinets and serves this function, but wouldn't be recommenced in small craft construction.
Old 11-01-2011, 01:00 AM
redreuben
Rep: 164 Posts: 352
"It has low resistance to shock loads and poor stiffness." That is what I needed to know, thank you Par.
Old 11-01-2011, 01:06 AM
sabahcat's Avatar
sabahcat sabahcat is offline
Rep: 257 Posts: 793
Originally Posted by redreuben View Post
Hi all,
Cheers,
RR
By the time you use an expensive gaboon, glass it, add stiffeners blah blah blah, would it maybe be more cost effective to use something like http://www.polycore.com.au/index.php or http://www.highpointtimber.com.au/pr...pplanking.html you can buy solid panels as well
Old 11-04-2011, 04:22 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,400
Hi all,
Cheers,
RR
One NA I have spoken to has done a number of tests on Plywood in Australia, and recommends Kakoda Brand Marine Ply for true lightness and quality. Some local builders have also added their endorsement.
Joubert Gaboon was well over the 'quoted' weights on the test sheets he bought. One boat designer found his boat kits were well overweight from Joubert Ply.
PS - Port Phillip Plantation Shutters in Melbourne is supposed to have the best prices on Kiri
Old 11-04-2011, 08:20 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Get a set of scales and a stack of ply would and weigh each sheet you will be amazed at the differance in the weight of sheets from the same stack .
Making beautiful boats is a passion never a chore !
Old 11-04-2011, 11:31 PM
Out of the 100 sheet delivery I just took, the Meranti was within 5% of it's spec and the Okoume was within 7%. If you toss out the odd ball sheets, both figures are half this, so the published data is accurate, though it might be wise to weight sheets in weight sensitive projects.
Resin Infusion - light weight method_nzd Fiberglass and Composite Boat Building 15 08-23-2011 03:49 PM
Light Weight Stern drive Mark Emaus Sterndrives 3 04-12-2009 08:48 PM
Light Weight Diving Vehicle dtoshni Boat Design 34 06-28-2008 12:39 AM
light weight lay up nordvindcrew Fiberglass and Composite Boat Building 22 09-18-2007 07:48 AM
Portager's Light Weight Engine Portager Boat Design 0 07-22-2003 01:57 AM
