  #31
Old 04-19-2009, 09:27 PM
Boston's Avatar
Boston Boston is online now
Rep: 1360 Posts: 3,257
in the process of repair Ive often found windows that survived surprisingly well for how poorly they were installed
catastrophic failure isnt that common its just far more likely to occur when the job is done poorly
  #32
Old 04-19-2009, 10:30 PM
Rep: 527 Posts: 792
I think a hidden factor is just how rigid (or flexible) the surrounding frame happens to be, or the Cte is close enough. Sometimes you just get lucky that way. Also, surface mounting is a big plus since the panel won't be 'trapped' all around by the frame. Through holes are still a problem, though.
I'm working on a plane right now where one piece of glazing was obviously mis-installed; not enough expansion room all around. But it's a 'clamped' rather than 'through-hole' installation so the whole window just caved in permanently, but no cracks anywhere.
Jimbo
Glass vs. Lexan as boat windshields and windows JonathanCole Boat Design 3 10-29-2006 10:35 AM
bending lexan sheets Ruxban Materials 3 08-01-2006 03:48 PM
Recommended sealant for replacement Lexan windows..? paularey Fiberglass and Composite Boat Building 2 07-28-2006 05:17 PM
lexan bonding GVQ Materials 14 10-12-2005 07:44 AM
thermoforming lexan lexansurf Materials 4 06-04-2005 09:33 PM
