Old 07-12-2011, 03:01 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,400
Keeping Resin and Epoxy warm - without catching fire.
I just gutted an old fridge to store Epoxy and other Resins in, away from the cold.
I have heard of some people putting low wattage light bulbs in to warm things up a bit, but I wondered what the risk of Vynelester fumes catching fire from say hot bits of the lightbulb or even sparks might be.
Any one have any thoughts about it ?
Old 07-12-2011, 03:12 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
I would say its Ok as it is
Old 07-12-2011, 07:40 AM
Rep: 1493 Posts: 7,447
I use an electric blanket.
Old 07-12-2011, 08:14 AM
Frosty's Avatar
I think he means just for storage.
Old 07-12-2011, 09:56 AM
Herman's Avatar
Herman Herman is online now
Resininfusion.info
Rep: 1043 Posts: 1,269
Couple of things:
For a fire / explosion you need the following:
oxigen (plenty around)
fumes (moderate to plenty around, needs to be between lower and upper explosion limit)
ignition (sparks from the bulb, or a surface hot enough)
With 1 or 2 low wattage light bulbs (say 30-40 watt) I GUESS you will not reach any limit, and your resins are nice and warm.
Old 07-12-2011, 05:41 PM
With an electric blanket you never get a very hot area, and they have a thermostat.
Old 07-12-2011, 09:20 PM
rwatson's Avatar
Thanks guys - the electric blanket gives me the warmest feeling ... but of course they are bigger than fridge and should never be used folded.
I need an electric bum-warmer .....
Old 07-12-2011, 09:46 PM
They make small heating pads too. I have one that is about 25cm by 40cm
Old 07-12-2011, 11:46 PM
Frosty's Avatar
Whoa your both talking wrong ends, one of you is talking about storing epoxy and one is talking about accelerating going off time in cold weather.
Old 07-13-2011, 12:09 AM
Saildude Saildude is offline
Rep: 92 Posts: 78
There are thermostats for home heating control of base board electric heaters that would do the switching fine, but I am not sure about how they would live in that environment. Around $ 25-- US dollars for the low tech ones.
Old 07-13-2011, 12:12 AM
rwatson's Avatar
I dont think anyone was mentioning catalyst going off in cold weather till now, but I wasnt aware it was ever a problem. I had always thought it was like Acetone, as long as it didnt evaporate, it was OK, and that heat made it deteriorate over time.
Its relatively cheap, so I was nt too concerned about it.
Also, I understand that you dont want to keep the catalyst and resins in the same container.
All suggestions welcome
Epoxy resin over poly resin ??? lobsterman Fiberglass and Composite Boat Building 5 05-15-2011 07:37 PM
Epoxy, Resin or What ? MEJETSKI2000 Fiberglass and Composite Boat Building 7 07-12-2009 02:52 PM
epoxy resin garrick Materials 1 01-16-2009 02:48 PM
Epoxy resin bulk-head Materials 11 01-05-2008 03:22 PM
epoxy resin? jstephen Wooden Boat Building and Restoration 5 02-23-2004 07:32 PM
