| keelmaterial for an alu sail boat! Hi all! I am planning to build a small aluminium sailor. though I do want the keel to have a higher dens. then aluminium. Of course I dont want the alu to bee corrogated by galvanic streams. Any suggestions of a good material! Not to expensive of course. The keel is still under design and should be a little deeper and a little bit shorter. The same opt. with the rudder. The data in the pdf file isnīt correct.
__________________ The more I learn the more I do understand that I do not understand. :) |
| Have you done any calc's, to confirm that you actually need a higher density material, for your righting moments? |
| Yes i do have a righting moment of about 0.47 knewton at 60 degrees. And i am not sure how much a sail does press the boat at the side. I do have a vert cog about 0.45 with myself placed on the durk. I am sure that you meant the boat boat to be as light as possible. And the hull is about 20kilos at the moment. If I do use Alu. The vertical Km is about 0.67meters above lowest point at bottom (without keel inkluded).
| A lead filled aluminum keel can work. You can cast the lead to the shape of the keel and set it in epoxy.
__________________ Gonzo |
| Yes Gonzo! Actually I did have this in my mind. But I wasnīt sure about the galvanic. But you mean this wouldnīt bee any problem to corrugating the alu in salt water. Of course I will use alu Aw 5754 wich is saltwater resistant.
| Ad Hoc! I also have to calculate the sail before I make the boat heavyer. thx! Janne
| The lead and aluminum will not touch if the lead is encapsulated in epoxy
| Ah oki! Then I can use any material as I want. ![]()
| ply tp alu | wardd | Boat Design | 4 | 10-09-2009 05:10 PM |
| hardening alu | sigurd | Materials | 10 | 10-05-2009 05:13 PM |
| Reinforcing alu chainplates | simon | Metal Boat Building | 3 | 09-24-2006 12:18 AM |
| Steel/Alu Folkboat | greybeard | Metal Boat Building | 7 | 10-24-2005 11:21 AM |
| Anodised Alu AlMgSi0,5 | Danielsan | Materials | 1 | 08-25-2005 06:48 PM |
