| Keel fairing strip Perhaps somebody could suggest a suitable material to attach around the opening of a swing keel to reduce turbulence when the keel is lowered. The keel is a foil shape and is about 3 1/2" wide at it's widest. I am building the boat using cedar strip and epoxy construction. Any suggestions appreciated. |
| Heavy sail cloth is a traditional material, rubber gaskets and just about everything else has been tried. I even saw a bicycle inner tube used, which attached inside the case and was hand pumped to seal the slot closed around the board. |
| Speed Strip tongue-and-groove strip planking | Jeff | Materials | 38 | 08-04-2009 11:12 PM |
| Sandblasting and fairing a cast iron ballast keel. | Mohan Pakkurti | Wooden Boat Building and Restoration | 1 | 01-17-2007 07:00 PM |
| keel fairing | rapscallion | Sailboats | 13 | 01-17-2007 04:25 AM |
| Fairing | bobsyachts | Boatbuilding | 6 | 07-08-2006 01:42 PM |
| Fairing | Smircio | Software | 12 | 12-10-2005 08:14 AM |
