Old 11-17-2011, 08:39 AM
dimr's Avatar
dimr dimr is offline
Rep: 10 Posts: 7
ISO hull thickness
I am studying hull bottom thickness with the regulation of iso 12215 -5 C.1
FRP laminate single skin
i found out Pbm Base :45,2 kN / m2 ..?
Pbm :33,36 kN / m2...?
t1 : 5.2 mm
1. question : Is this minimum 5.2 mm thickness of bottom (Chopped strand mat +viny lester +catalizer ) a CORRECT approach for a 7.5 m fiberglass boat?
2. question : how many layers of chopped strand mat should i use for bottom ?
450g (1.5 oz) Chopped Strand Matting +2.5 kg of Resin will “wet out” 1kg of Chopped Strand Matting
Property Description
Glass Type E
Binder Type Emulsion
Filament Diameter micron : 11
Coupling Agent Silane
Mat Density g/m˛ 450 & 600
Mat Width m 0.95, 1.27 & 1.37
Displacement kg 2040
Heel to Starboard degrees 0
Draft at FP mm 0,44
Draft at AP mm 0,44
Draft at LCF mm 0,44
Trim (+ve by stern) mm 0
WL Length mm 7,198
WL Beam mm 2,233
Wetted Area mm^2 16,9
Waterpl. Area mm^2 12,174
Prismatic Coeff. 0,765
Block Coeff. 0,282
Midship Area Coeff. 0,552
Waterpl. Area Coeff. 0,758
LCB from Amidsh. (+ve fwd) mm 3,124
LCF from Amidsh. (+ve fwd) mm 2,908
KB mm 0,322
KG mm 0,46
BMt mm 1,863
BML mm 21,176
GMt mm 1,725
GML mm 21,037
KMt mm 2,185
KML mm 21,497
Immersion (TPc) tonne/cm 0,125
MTc tonne.m 0
RM at 1deg = GMt.Disp.sin(1) kg.mm 61,406
Max deck inclination deg 0
Trim angle (+ve by stern) deg 0
Old 11-22-2011, 09:17 AM
dimr's Avatar
Rep: 10 Posts: 7
thanks for all replies...
delftship hull thickness??? metin_mehel Software 24 02-26-2012 02:36 PM
Standart ISO for FERROCement hull theiera Materials 5 03-30-2011 06:51 PM
Hull thickness??? monrosm@shrewsb Boat Design 4 02-04-2011 09:18 PM
FRP hull thickness tdamico Boat Design 19 09-14-2004 08:20 AM
How to calculate the thickness of a hull? jb Boatbuilding 3 11-07-2003 09:12 PM
