Old 09-22-2002, 12:04 PM
Alex Hall Alex Hall is offline
Insulation
Am restoring 1959 steel gaff cutter built in Holland. She never had insulation, notwithstanding having sailed to as far away as Norway and the West Indies. The interior steel is in excellent condition and only pitting was underneath heads.
Am wary of spray on foam, also unobtainable here. But the yacht I work on which is also steel has rock wool and with 5 crew and 8 guests condensation does not seem to be a prob, but the rock wool does get wet.
The alternatives are something like neoprene or cork. There existed paints with a high % of cork granules and seemingly worked well against condensation.
Has anybody used any of the above or owns boats which have?
Old 10-06-2002, 03:12 PM
big cat big cat is offline
Rep: 10 Posts: 11
Owens Corning makes a product for basement walls that might be useful. It has an r-11 rating, can be removed for inspection, the exterior is a matt fabric, with a channel at the bottom for wiring. Being made for sub grade applications it should handle marine applications also. Try www.owenscorning.com then go to basement finishing.
Bob
Old 11-16-2002, 04:16 PM
insulation
look at www.supertherm.ca
we have had great success with this insulation.
go to thermal then supertherm
for more information contact A.J. at technologynw@attbi.com
Old 12-04-2003, 03:32 PM
edwardo edwardo is offline
We have started using Thinsulate from 3m, Great product with great sound and thermal qualities. Worth a look if you ask me
Old 12-04-2003, 05:53 PM
mmd's Avatar
mmd mmd is offline
Rep: 290 Posts: 378
Read the postings on the "Insulation" thread at The Metal Boat Society" website at http://www.metalboatsociety.com/phpBB2/index.php
Good stuff there.
Long - Skinny Power Boats SAQuestor Boat Design 164 11-12-2009 06:28 PM
aluminum interior insulation Metal Boat Building 28 02-06-2006 07:54 PM
thinsulate sound insulation nilo Open Discussion: All Things Boats & Boating 12 02-15-2005 03:31 PM
insulation for sale AAllen Marketplace 1 01-10-2005 04:45 PM
insulation Materials 0 11-16-2002 04:24 PM
