Old 09-21-2007, 09:08 AM
lorri lorri is offline
Rep: 10 Posts: 18
info on cheap way to glass hull
Hi I wondered if anyone can tell me a cheap way to glass the hull. Its stripped down to the bare ply now so we have to start on it soon.We are not worried about having a show boat,just doing repairs on it and want to get her into the water.We need to know what fiberglass mat/cloth and resin to use as not sure with all the types out there.
Thanks Lorri
Old 09-21-2007, 11:02 PM
Rep: 2891 Posts: 8,796
Since you've already had experience with a cheap 'glass job (and peeling it off), you should consider a more durable and more stick-um type of sheathing. You basically have three choices, polyester (which you likely peeled off and caused your rotting issues), vinylester is a little more costly but does a better job and lastly epoxy, which will stick it down good and costs a little more. Polyester doesn't stick to wood well and it's generally not a good choice. Vinylester is a better choice, but epoxy is the ticket and the hands down recommendation for many reasons, especially its ability to stick and stay stuck.
Old 09-21-2007, 11:26 PM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 604
Epoxy & biaxial fabrics with a mat backer. Look for 1708 or similar in the cloth. Very easy to wet out and strong.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
rough costing of a 20m (65ft) glass hull Packeteer Marketplace 1 10-03-2007 09:12 AM
I'm looking for hull design info =D= Boatbuilding 4 07-22-2005 06:41 PM
Glass over good plywood hull? Ed Hoban Wooden Boat Building and Restoration 10 02-11-2005 01:26 AM
A Thick Glass Over Ply Hull? NEILIUM Wooden Boat Building and Restoration 12 10-09-2004 08:03 PM
clasic glass hull bud Powerboats 10 08-22-2003 01:17 PM
