Old 03-18-2011, 07:34 PM
CatBuilder CatBuilder is offline
Rep: 1308 Posts: 3,040
Inexpensive, Lightweight Core for Interior Uses?
What would you use as a core material or building material to build an interior out of if you wanted...
*lightest weight
*economical
*will last as long as the boat
The material would be for non-structural items like settees, cabinetry, cabin sole, tables, counters, etc...
Kurt Hughes was right about this place.
Old 03-18-2011, 11:32 PM
PAR PAR is online now
Rep: 3125 Posts: 9,403
Why use a core under those requirements?
Old 03-19-2011, 01:47 AM
Rep: 670 Posts: 2,457
I guess your talking about sheet produces for interior furniture. None is particularly cheap. The production boatbuilder JBoats use Goldcorelight
http://www.kerfkore.com/
http://nida-core.com/english/nidaprod_lamin_veneers.htm
http://www.pantimusa.com/feather_ply.html
http://www.goldcorelight.com/specifications.htm
Old 03-19-2011, 05:18 AM
Yes, why indeed?
How would you build the lightest interior?
Thanks for the links, Michael.
Old 03-19-2011, 05:47 AM
And go crazy saving weight on interior components. It makes a huge difference. The boat Im sailing now is one hudred percent cored panel interior. You might be wise to checkout a furniture building website blog like fine woodworking or something for tips and tricks when working with light panels...hinges, backing plates , mollies....and veneer tricks. If possible visit a lightweight modern boat like a Wally with your camera and record details.
Old 03-29-2011, 06:26 PM
AndrewK AndrewK is offline
Rep: 338 Posts: 377
Catbuilder; if you want lightweight and economical then light weight plywood is your best choice. Locally I can get a 12mm, 10.5kg sheet of balsa ply for $60. This is made from 3 thick veneers of long grain balsa with thin hardwood faces. This is definitely for non structural work, there are also other plywoods 13 - 15kg a sheet that are good for light structural work.
Talk to your local mobile home manufacturers to see how they make their interiors and where to source the plywood from.
Next on the economical scale I found is plastic honeycomb core from Plascore, http://www.plascore.com/ The last price I had is ~18 months ago $45 a sheet for 10 & 12mm. You can face this with 1.5 - 2.0mm 3 ply or glass them.
Andrew
Old 03-29-2011, 06:34 PM
bobothehobo bobothehobo is offline
Rep: 47 Posts: 63
I use these roosters:
http://www.eastcoastinteriorsinc.com/
Old 03-29-2011, 07:23 PM
rberrey rberrey is offline
Rep: 69 Posts: 287
Cat, I dont know about inexpensive but I will be using all 5/8 foam same as the hull, I bought case price so I just added in interior. When I added up shipping with plywood prices I decided I would break about even going with foam on my bulkheads and furniture. If there is no structural intent in the design of the furniture ect. a cheep foam with no shear strength may do, I think fiberglass supply stocks one. rick
Old 03-29-2011, 08:12 PM
Steve W Steve W is offline
Rep: 360 Posts: 686
kraft paper honeycomb such as verticel sandwiched between doorskin ply makes nice lightweight stiff sheetgoods for a reasonable price. The interior is a good place to save weight.
Steve
Old 03-30-2011, 12:08 PM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1117 Posts: 1,648
I've been asking questions about foam cores after I read about Jorma Ponkala.
http://shalom.ponkala.net/pages/shal...in-english.php
http://www.solarnavigator.net/solar_boat.htm
http://translate.google.co.uk/transl...26prmd%3Divnso
Here is the product specification.
http://www.finnfoam.lt/client/frontpage//english.pdf
It's not available in the UK, but here is the text of an email from Finnfoam.
Finnfoam is xps (extruded polystyrene).
Xps boards are sold in England at least with trade marks:
Styrofoam by Dow Chemicals
Polyfoam by Knaufinsulation
Styrodur by Basf and sold by FOAMtech Ltd
Mr Ponkala has during past 20 years made many kind of constructions using Finnfoam and glassfibre. Shalom is his second boat.
Best regards
Seppo Paasi
Thus.
http://www.knaufinsulation.co.uk/pro...loorboard.aspx
Price in UK.
http://www.building-supplies-online....ard-3243-p.asp
AFAIK, 20% of the cost of Diab foam cores.
Cat Builder, search your locale and try a sheet for yourself.
regards,
P
Whilst entitled to your own opinion, you are not entitled to your own facts!
Old 03-30-2011, 05:02 PM
War Whoop War Whoop is offline
Rep: 84 Posts: 661
http://www.tricelcorp.com/apps_home.html
Slippery when wet.
www.cheetahcat.com
Old 03-30-2011, 07:40 PM
Thanks for all the advice, guys. I'll look into them.
Old 03-31-2011, 07:42 AM
Pericles's Avatar
Shear strength of Finnfoam is 300 kPa, about 43.5 Pound Per Square Inch
1 Kpa (Kilopascal) = 0.145037738 Psi (Pound Per Square Inch)
Shear strength of Divinycell H is 400 kPa or 58 Pound Per Square Inch
http://www.diabgroup.com/europe/lite...df/H_DS_EU.pdf
Old 04-01-2011, 09:55 AM
Herman's Avatar
Herman Herman is online now
Resininfusion.info
Rep: 1043 Posts: 1,269
Also you could do a couple of phone calls, see if you can find a batch of "B-grade" foam. Usually nothing is wrong with it, just odd sizes, thicknesses, or a corner that broke off.
I also once bought 5 or 6 containers full of thin sheets Core-Cell, in full, half and quarter sheets. That was something. Many structures in Holland were built using these sheets.
Old 04-01-2011, 11:14 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1874 Posts: 3,357
There are always bargains to be had. I saved money on plywood by haggling over damaged corners.
Hoyt
inexpensive plywood meducks Materials 51 02-23-2011 10:31 AM
Looking for lightweight material for interior Niilo06 Boat Design 17 12-23-2009 04:42 PM
Inexpensive Plywood Design Software??? James Mills Boat Design 2 10-13-2007 08:34 AM
Needed - inexpensive core material Martell_Florida Boat Design 10 07-14-2007 02:30 PM
Inexpensive Source For Spline Weights SplineWeights Education 4 08-15-2005 04:19 PM
