| I purchased sets of plans four years ago, for both the DE25 and the LB26 from Bateau.com. Using the building instructions of both plans, I am going to build something with a superstructure that resembles the look of a Thames 25' saloon launch. http://www.peterfreebody.com/downloa...sue32_1991.pdf The LB26 plans recommend foam core and as the DE25 is the easier hull to construct, I shall marry them together. This is going to be a rivercraft only, so ultimate strength is not necessary. The boat would be so light, only a 15 hp 4 stroke outboard would be required. 2 litres per hour @ 8 kph. Knauf Polyfoam is the same specification as Finnfoam, so I have done some costings for UK construction. The DE25 plans call for 28 sheets of 10 mm and 9 sheets of 12 mm BS1088.The 12 mm 5 ply sheets are available @ £43-32 per sheet but it would have to be Robbins Elite 9 mm 5 ply @ £65-55 per sheet, costing a total of £2225. Dat's alotta dosh! ![]() http://www.robbins.co.uk/pdf/Marine_Pricelist.pdf Using Polyfoam, 40 mm hull bottom @ £10-51 per 1200 mm x 450 mm sheet and 35 mm hull sides @ £9-27 per 1200 mm x 450 mm sheets, the DE25 plans would require 24 sheets each of both thicknesses, about £480-00. VAT of 20% is ignored for now. Foam core requires more epoxy resin and glass cloth, but using Polyfoam would save £1745, which buys a considerable amount of epoxy resin and glass cloth, over and above the 30 gallons etc., that the DE25 plans originally call for: http://www.bateau.com/studyplans/DE2...od=DE25Cockpit Money, money money, I must save some money, I'm a poor man now! ![]() ![]() ![]()
__________________ Whilst entitled to your own opinion, you are not entitled to your own facts! |
| inexpensive plywood | meducks | Materials | 51 | 02-23-2011 10:31 AM |
| Looking for lightweight material for interior | Niilo06 | Boat Design | 17 | 12-23-2009 04:42 PM |
| Inexpensive Plywood Design Software??? | James Mills | Boat Design | 2 | 10-13-2007 08:34 AM |
| Needed - inexpensive core material | Martell_Florida | Boat Design | 10 | 07-14-2007 02:30 PM |
| Inexpensive Source For Spline Weights | SplineWeights | Education | 4 | 08-15-2005 04:19 PM |
