| Identifying aluminum type used in my boat rails Newbie here (in many ways ha) and I hope this is the right place to post this question. I have a '95 Hurricane Fun Deck that has some bent railing and I also want to custom construct some new railing features. The aluminum railing is 1 1/4" square tubing but I don't know what type it is (6063 etc.) so I can't buy the correct welding rods. Hurricane/Godfrey Marine hasn't returned my call for info. Does anyone have any other method to get this info. I should note that I'm by no means knowledgeable about metals and welding aluminum (yet) and I have bought quite a bit of scrap to learn on, but I've read enough to know I need the right kind of rods. Also, do you know of a source where I can order this square tubing? I know I'm gonna need quite a bit of practice to do a decent job and I want to practice on the exact stuff I'm welding. Thanks, David |
| These people offer all type of aluminum product in marine grades 5086, 6061, 6063, etc http://www.alaskancopper.com/ here is another. http://www.eaglealloys.com/c-19-alum...eet-plate.aspx |
| Thanks, rasorinc. I'll check it out. Now if I can just find out what kind of aluminum I have on the boat now I should be set for lots of gobbing practice ![]() |
| Take a piece to a welding shop that advertises aluminum welding. They should know and especially if they weld boats. It may very well not be a marine grade. that is called doing it on the cheap. |
| It's probably 6063 if it's the typical bent stuff seen on most of these types of boats. 6063 is selected because it bends easily and has good corrosion resistance, though is only about half as strong as 6061 in tension. |
| Help Identifying a boat | pcmpete | Open Discussion: All Things Boats & Boating | 0 | 04-24-2009 02:27 PM |
| Need help identifying this boat | kamouflage | Boat Design | 3 | 04-04-2009 07:12 PM |
| HELP identifying boat | thefuture | Powerboats | 12 | 02-18-2009 11:46 AM |
| toe rails and rub rails | fishweed | Wooden Boat Building and Restoration | 16 | 03-03-2007 09:40 AM |
| Type of Aluminum | Scott Lipp | Boat Design | 11 | 06-22-2006 03:20 PM |
