Old 10-09-2006, 06:10 PM
paularey paularey is offline
Rep: 10 Posts: 32
Ice-box corner filet material under epoxy & glass…what to use..?
I am just getting ready to finish the final assembly of a rather large built in ice-box under the cockpit seating area of my catamaran and I was wondering what might work best for filleting/adding a small radius to the corners before laying some fiberglass tape to the seems with epoxy resin…? Brief description my ice-box is approximately 24 inches deep by 24 inches wide by 34 inches across. And is made out of 4 inch thick Styrofoam panels with a thin but solid layer of woven fiberglass & chopped strand matt combination bonded to one side with epoxy resin. I fitted the pieces (foam only) in place then removed them individually and glassed the interior portions while horizontal in my shop. The panels turned out really nice. Now I just want to install them into the ice-box frame and seal all the corners with a narrow stripe of fiberglass tape but I would like to lay a small radius of some kind of filler/fairing compound in the corners before doing so. I was going to us a polyurethane chalking but I thought it might be better to have a solid material to back up the glass. I am in Panama so my resources are limited. Is there anything wrong with using bondo or a similar material? I only plan on laying in a small radius so the tape will transition the corners smoothly. I am a novice with composites so any input is appreciated. I would like to avoid something that can absorb water and lower my ice-box efficiency.
Thanks
Old 10-26-2006, 10:08 AM
Rep: 1397 Posts: 7,216
If this is just for waterproofing, bondo will work fine. After it cures, sand it and dewax it for better adhesion.
Old 10-26-2006, 11:52 AM
John ilett's Avatar
John ilett John ilett is offline
Rep: 23 Posts: 131
You should just make some filler for the fillet, sand when dry and lay your tapes on top. Use the same resin for the fillet with a suitable filler, maybe Q cells, micro balloons or similar.
Hull material for a stationary houseboat, ice skyl4rk Materials 10 09-28-2006 11:21 PM
Built in ice-box foam....what's best? paularey Fiberglass and Composite Boat Building 14 07-26-2006 10:14 PM
glass/epoxy over wood jomo Boat Design 4 11-22-2005 10:54 AM
epoxy and glass inside and outside? and more Nordson1960 Wooden Boat Building and Restoration 6 05-22-2005 09:26 PM
Ice Box Rebuild Lew Morris Sailboats 15 07-11-2004 08:14 PM
