  #31
Old 01-31-2009, 09:05 AM
apex1
Originally Posted by teakcell View Post
I did. Thanks
Laurent,
my guys here ask me "why is he using Xylene?" "If the bonding resin bleeds through, evenly distributed, just add two more layers (green) and the race is ran" Why Xylene?
Regards
Richard
  #32
Old 01-31-2009, 12:47 PM
Rep: 2891 Posts: 8,798
Xylene isn't a bad choice, especially if you want to increase the flexibility of the cured goo. At the right temperature, it can also increase penetration, of course with the knowledge it will reduce strength and water proofness of the cured coating.
I know what you're going through Teakcell. Those seams will suck up resin like a sponge. My technique was to apply a few coats to the seams only, to fill them, knocking down the over flow after each run. It's a pain, but the only way to level the seams with the curved veneer surface I was working with.
Another option would be to "flood" coat the surface. This is much like how a table top is done. You literally pour on the epoxy and let it pool. I use a 1/16" notched spreader to move it around the surface, which self levels if the viscosity is correct and the resin has enough time to flow out before it kicks off.
For panel work, I would think flood coating is the way to go.
  #33
Old 01-31-2009, 04:11 PM
apex1
Thank you PAR
To this point my first reply should lead (post#4)! Feed more resin.
Regards
Richard
  #34
Old 01-31-2009, 04:29 PM
robherc robherc is offline
Designer/Hobbyist
Rep: 102 Posts: 433
Yes, good idea too. I don't really have trouble with Ep going through the veneer and I would even say that I like that because it cannot be better bonded. My problem comes after applying another layer of ep and additionnal Pu varnish ...
Here's a thought (possibly useless, maybe not) that just hit me:
Why not saturate the veneer with epoxy first? That way there will be no bleed through (though, if done right, the cured bond should be as good), and there will be no "dry spots"...just evenly epoxy-soaked wood. You could probably even VIP (with flow media, of course) or vac-bag the veneer when you do this to keep from gaining too much weight from over-applying the epoxy, if weight is critical for you.
  #35
Old 01-31-2009, 04:33 PM
Designer/Hobbyist
Rep: 102 Posts: 433
To All:
In another thread, teakcell told me he uses veneer over honeycomb. If that's the case in this thread too, then I think we're talking "weight-critical" applications, and feeding more resin into the vacuum might just rapidly increase weight by filling the honeycomb with epoxy. If that's not the case here, then "feed more resin" could be exactly what the doctor (Dr. Richard?) ordered.
  #36
Old 01-31-2009, 04:47 PM
apex1
Rob
you are right, we are talking "weight-critical" applications. But the honeycomb cells are already covered by plywood to which teakcell will apply the veneer.
So I doŽnt see a real prob feeding a spoon of additional resin.
Regards
Richard
  #37
Old 01-31-2009, 06:13 PM
Designer/Hobbyist
Rep: 102 Posts: 433
OK, I guess you have more info than I do on this one...if he has already applied plywood to the honeycomb, then yes, I would say feeding a little more epoxy would prob. be the easiest way to fix the problem...do the same thing as a pre-preg. veneer, but without the extra step.
The Perfect Sharpie Brasstom Boat Design 15 03-23-2011 01:04 PM
Perfect Sean Herron Boat Design 5 12-14-2008 05:35 PM
Honeycomb panel Gypsie Materials 2 07-11-2008 08:00 AM
How do you design for the perfect trim? Omeron Sailboats 12 05-17-2008 06:14 PM
The Perfect Sailboat... Sean Herron Boat Design 16 09-21-2005 02:15 AM
