Old 06-26-2004, 12:53 PM
chkmahow chkmahow is offline
I need HELP! AWLGRIP PAINT OVER GELCOAT
I just bought a 1988 SHAMROCK and Imp going to paint the bottom and sides with AWLGRIP.
#1) I had to remove about 6 coats of bottom paint witch went up the side of the boat 12".
#2) I striped off all attached parts and filled all scratches and any hole not needed.
#3) I sanded the bottom and sides of the boat smooth, raped and taped off all other items ready for paint
#4)I baught Awlgrip G8010 and Awl-cat #3 converter to brush the bottom, because it on a trailer and I can only do one side at a time. For the sides I have Awlcraft 2000 with Awl-cat #2 converter for spraying.
#5) I NEED HELP!!!!. The saleman said I didn't need to prime before I paint the boat if I would sand the boat good and clean of all dust. WHAT SHOULD I DO????? THE BOAT IS ALL READY TO PAINT TO DAY June 26,2004
Thanks
Jim
Old 06-26-2004, 04:30 PM
Corpus Skipper's Avatar
Corpus Skipper Corpus Skipper is offline
Hopeless Boataholic
Rep: 173 Posts: 604
Jim, just my opinion, but I think you should prime and sand before painting. This will help to show any minor surface imperfections you may have missed. A good filling primer block sanded before painting will give you a beautiful finish. You spent the money on the Awlgrip, might as well go all the way. I think you'll be thankful that you did.
Craig Cavanaugh
Silver King Custom Marine
No shoes, no shirt, no problem!
Old 06-27-2004, 12:14 AM
Rep: 1397 Posts: 7,216
You should use a sealer and a primer. If not the pores on the gelcoat will show as craters. Also, old wax and sealers are usually lodged in those pores.
Spraying gelcoat over gelcoat alexhiguera Fiberglass and Composite Boat Building 9 08-26-2005 11:09 PM
gelcoat over paint gofishing Boat Design 2 04-12-2005 09:20 AM
Help needed: metalflake and gelcoat on my bassboat!! challenger83 Boat Design 0 03-13-2005 04:55 PM
Gelcoat vs. paint (LP)? mattotoole Boatbuilding 5 03-08-2005 01:46 AM
Gelcoat Peeling&Bottom Paint Stripping Marlin111 Services & Employment 1 01-01-2002 07:01 PM
